VRIL Counter-Rotating Fields
Started by bowser03, October 28, 2007, 08:19:17 PM
bowser03
I have another invention, which is a Clean Energy Tool which I call the Buddha Resistor, which is an intelligent Psychotronic Load which should do amazing things to whatever current passes through it is modified by the resistances which make up the compound resistor.  This includes making batteries recharge, money magnets and other things, like meditation and blessing circuits and transuniversal tapping circuits.  It uses the name of God in all the Universes, the Large (Elyown), the Middle (Elyown) and the small (El) coded into the resistances as numbers for letters, for example E would be the fifth letter of the alphabet, or 50 ohms is selected and so forth.
I have not tested this circuit yet, or built it, but will build it soon because I want to make some money with it using a coil to magnetize the currency with the name of God in multiple dimensions.
I have posted the schematic of the resistor here.
bowser03
Vril is the divine name for God, therefore even if we do not use counterrotating magnetic field initially, if we call upon the name of God we will end up with them.  I have attached my divine name toroid schematic, a prototype of which I have just built a few minutes ago just to see what would happen.  I have also attached the photograph of the working toroid which is presently modifying the field characteristics of a mini Vogel Crystal, giving it the maximum magnetic field flux and electret's field.
The Quran warns that the nonbelievers would have the lesser intelligence.  You were warned.  Hellfire is awaiting you and I have visited there before.  I  drove the trucki bomb in the Beirut Bombing of the Marine Embassy.  I also pressed the detonation switch.
bowser03
Since the Vril Circuit is running off the battery and producing enough power to recharge it for 3 days I have posted here a self-running version of the circuit using super capacitors.  Jolly Ho!  I plan to get this circuit version running in a week or two.
bowser03
Attached is the proposed self-running circuit, which should put out 415W at 47A and 600V.  We will see soon.  I am not using super caps on this circuit.
hansvonlieven
Quote from: bowser03 on November 04, 2007, 01:26:42 AM
G'day all,
I didn't know that Edward Bulwer-Lytton invented and named God. He certainly invented the term Vril and the story of the super race that went with it. If you have to have a fantasy Bowser, why not pick an original one instead of wallowing in this old rubbish.
Hans von Lieven
QuoteThe Coming Race (original title), also reprinted as Vril: The Power of the Coming Race, is a novel by Edward Bulwer-Lytton published in 1870. The novel is an early example of science fiction, sometimes cited as the first of this genre. However, many early readers believed that its account of a superior subterranean master race and the energy-form called Vril was accurate, to the extent that some theosophists accepted the book as truth. Furthermore, since 1960 there has been a conspiracy theory about a secret Vril-Society.
Source Wikipedia
