VRIL Counter-Rotating Fields
Started by bowser03, October 28, 2007, 08:19:17 PM
Earl
Hi Bowser03,
I just returned from a Swiss energy conference and an elderly German man was there who said he worked with the VRIL project and also worked with Hans Kolar.
He did not have anything to do with Haunebu.  His description of the VRIL device was a propeller on top pulling air down and exiting over "bars" of uranimum and cadmium(? used as moderator?) .
This heated the air extremely hot and it was with this the saucer lifted off and disappeared within seconds.  Basically hot-air propulsion.  The crew of 3 laid horizontal on their stomachs; one pilot and two prisoners because the radiation level was quite high.
This is in strong contrast with rotating fields.
Referring specifically to your image, I have taken the liberty to redraw it and save in GIF format.  Notice that opposing magnetic fields do not work with only 3 coils, 4 will be necessary for proper magnetic orientation.  The inconsistency is shown in red color.  Would you please be so kind and explain?   I personally am a fan of quadrature, but not 120 degrees.  I see quadrature many places in Nature, but have never seen Nature using 120 degrees.  Perhaps someone can open my eyes and point out where Nature uses 120 degrees.  Tesla's first AC generators used 4 coils in phase quadrature.
The self-oscillating nature of your circuit is what I call a rat race because it resembles a rat running in a circle, chasing its tail.  As I see it, your circuit depends on differences of inductance, resistance, transistor beta, etc in order to cause one of the rat race transistor to conduct slightly before the others.  Whichever transistor is first to conduct starts the oscillation.
Back in July 2007, I published rat race circuits using ICs that could be clocked at very high speeds and also indicated that they could be used to generate counter-rotating fields.
In contrast to transistor circuits, my IC rat race has very fast transitions in the low nanoseconds and at can have pulse widths of 10ns or less.
http://www.overunity.com/index.php?topic=2582.msg38506#msg38506
http://www.overunity.com/index.php?topic=2582.msg41927#msg41927
When you say you have successfully tested this VRILian free energy circuit, please advise exactly how and in which manner you extracted the excess energy.
I see no methods to do this in your present circuit.
Sincerely, Earl
Quote from: bowser03 on October 28, 2007, 08:19:17 PM
The actual secret of Free Energy is given as the power of "Vril' which is caused by two rotating magnetic field's interaction.  This is what my Father, the real Hitler used to have German Astronauts travel to the Moon and discover cities and life there in the 30's.  He used Vril saucers.  Vril can be produced by a series of 2 electromechanical disks in a homopolar like, full flux design, or it can be produced by rotating two magnetic fields with field coils in a toriod using a solid state methodology.  i have attached a drawing of a successful vrillian free energy circuit which i tested today.  Please don't take this lecture i am giving you too lightly, since i have 6 Phd's and 4 Nobel Prizes under alias names and no other human on this earth has ever had more than one Prize per person.
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
karl
...Seikes forced feedback amplifier configuration...
...with Metaglas toroid...
In basic configuration called transistorized coil because it consists of one inter(chopped)ruped winding.
Naudin has a setup on his site.
Due to full resonance a positive current and a negative current is flowing in the winding.
It's basicly a closed loop.
Never tested this.
A 3 phase generator-amplifier in self resonance with a slightly frequency shift due to drift of the transistors.
Some (also Prof. Seike) are interpreting the drift as an energy+ of gravitational energy.
Driven conventionally with dc...Output is conventionally 3 Phase (120?).
Nieper and Seike used it to drive an exotic material disc (or ring? bacause it was called Nieper-Ring) which is believed to loose weight.
An verry interesting simple schematic which is also used at low frequ. to dimm tree bulbs etc.
Best wishes
Kark
bowser03
This power cell is the equivalent of an Orgone Battery when it is connectede to a 6 V lantern battery.  I am using 2N2222 transistors right now in the circuit but will later replace them with higher power microwave transistors.  The interesting part about the cell is that there is no voltage drop across the battery and for all purposes there should be at least 4 volts dropped, or 2/3 of the voltage because of the coil short circuit.  This proves that even under full flux vectors the circuit is drawing a negative load and therefore negative entropy like an Orgone Cell.  I will plan to use this cell to power a remote Joe Cell I have under stage I.
devilzangel
well .. i was able to search but .. ahumm .. http://groups.google.kg/group/alt.alien.research/browse_thread/thread/fbc79cb8fb27201c ... wiiiierd to say the least
btw .. how is related to the TPU?
devilzangel
amigo
Hi bowser03,
Could you please post some photos of the circuit you have tested, with the detail on the coils, their winding and inter-connection?
Thanks.
