Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
Bruce_TPU
Quote from: Rosphere on January 20, 2008, 10:00:29 AM
We assume that the two currents do not cancel each other out because we see the bulbs (LEDs) glowing, but what of the magnetic fields?
If the current is flowing both ways in the test wire, what of the magnetic fields; do we also have two opposing magnetic fields around the test wire or do they cancel each other out?
Hi Mike,
When I tested the "same signal, each opposing, two different sources, same wire", using a two frequency gen's, back in my thread, I used a magnet to test for a magnetic field.  It was huge, compared to one signal.  I posted all about it, but no one followed up on it.
Also, Thaelin, did similar experiments and saw 150 volt spikes, and ran a small motor using the same technique.  Very astounding stuff.
@ All
I think anyone serious about working on the TPU should consider investing in an accurate gauss meter.  IMHO.  It would assist in so many ways, testing for field cancellation, strong magnetic fields, different magnetic field strengths associated with different frequencies (my theory.).
Cheers,
Bruce
eldarion
Hi Bruce,
Can you please post a link to your ""same signal, each opposing, two different sources, same wire", using a two frequency gen's" experiment post?  I do not recall ever seeing that one, and it sounds interesting.  Maybe for some reason others didn't see it either and therefore it was overlooked?
Thanks! ;D
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on January 21, 2008, 01:21:58 AM
Hi Bruce,
Thanks! ;D
Eldarion
Hi Eldarion,
This is the first post I made talking about same signals:
http://www.overunity.com/index.php/topic,2300.msg35958.html#msg35958
My Quote from BEP here:
http://www.overunity.com/index.php/topic,2300.msg36406.html#msg36406
Thaelin's Information here:
http://www.overunity.com/index.php/topic,2300.msg36492.html#msg36492
Another post about same signals here:
http://www.overunity.com/index.php/topic,2300.msg36894.html#msg36894
http://www.overunity.com/index.php/topic,2300.msg36917.html#msg36917
My experiment, here:
http://www.overunity.com/index.php/topic,2300.msg36995.html#msg36995
eldarion
Thanks Bruce!
I think I'll go ahead and try it out--at least I can provide a confirmation of something unusual, or maybe even some more detail with my 500MHz  scope. ;)
Eldarion
-- Thomas Paine
hansvonlieven
G'day all,
Perhaps a little off the subject, but on reading your experiments I had an idea which I think is worth following up.
Instead of using a single wire if you used two electrodes immersed in an electrolyte instead you might be able to observe phenomena that could give you a clearer idea what you are dealing with. What would happen here? Would you get oxygen and hydrogen bubbles on BOTH electrodes or what? What happens if you pulse the current and so forth.
I will be trying this as soon as I have a chance.
What do you think?
Hans von Lieven
