HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
M@rcel
QuoteATHER  THING  I SAID  THAT IS EASY TO MOVE ELKTRONES  BUT IS HARD TO MOVE ELKTROMAGNET FILD
This reminds me of the Faraday generator: Whether you move the magnet or not makes no difference, the magnetic field doesn't move. The induced electric field, however, moves with the solid rotor.
AhuraMazda
We know so little about magnetism but I want you to consider this:
If light is passed through a fiber optic cable, when the cable is straight, all the light comes out at the other end uniformly.
But, if you bend the cable, the photons on the inside travel faster through the medium and you get a different colors at
the other end.
Would this also be the case for a magnetic field forced to bend?
AM
Turz
Hi Macedonia CD
I've read your posts.... let me know if I'm right
Take a look at the picture:
We must setup two Tesla primary coils but not the secondary, the secondary is another primary coil.
with this configuration we will have:
1) AC and DC together like SM said
2) two caps one for each coil like SM large TPU (maybe like you suggest 0,22 nF 1500V)
3) a spinning magnetic field like Zapnic suggest in his post  (spinning compass http://www.youtube.com/watch?v=G4Mr_0S7zqw)
4) a "vacuum like a tube" because we must have a "hole" in the middle of the coil
So let's spin this MF like a gun bullet with fast discharge of caps!!!
But at this point?
1) What about frequencies?
2) What about materials?
3) How collect something useful?
Let's think about frequencies......maybe
Freq 1 is WHEN discharge cap1
Freq 2 is WHEN discharge cap2
Freq 3 is WHEN catch something
Let's think about materials......
we must use copper (CU) and iron
we must use baling or litz wire (many wires are better than one)
Let's think about catch something useful......
at this point we can setup two configurations:
a) the two Tesla coils are made of copper ad there is a third coil/s to collect made of iron ?
b) the two Tesla coils are one made of copper and one made of iron and we use directly the AC in these coils?
And about your post
HE WORK  VERY HARD TO FIND THIS AND HE HAS MANY NOT WORKING DIVICES  BUT  FINALY  IS  SUCSES IS MADE>
AND  THE END OF THIS   <<STORY  OF SOME SUPER NATURAL PEOPLE  HO HAS ABLE TO SEE  THE  WORLD  IN ATHERE WAY >>THAT IS  TELL ME HO IS THAT MAN
The answer is Nikola Tesla
Let me know what you think
best wishes
Turz
sparks
       Say the tpu's input magnetic field squeezes the electrons into the core of the collector/generator coil..   This leaves you with a low pressure electron density on the outside of the generatator winding.  A positively charged surface.  So the collector windings now appear as a big old low pressure area to anything negatively charged.  So electrons start to migrate towards this low pressure zone.  They will experience a Coriolus force that will deflect them into a vortex current whose direction depends on which hemisphere you are in.  This Coriolus force just happens to be the same way a magnetic field will bend a current.  So now you have a pulsating vortex current circulating on the surface of the generator winding.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MACEDONIA CD
hi     im a glade  what  im read here  and  is good thing is here  for yours reply
@ TURZ   YOU THING THIS   IS THAT IS THE  FREKFENCY HMM  NO  IS NOT FREKFENCY  BUT IS  CIKLUSE OR  <,PERIODE >>IF IS FREKFENCY  K.M   WHILL NOT  PUT  DC  ?AC CONVERTER  TO PUT  THERE  <<TV RECIVER  AND  DRILL >>.
WHEN IS SAID   6000 HZ  IS NOT HZ  BUT IS SOMTHING ELSE  <<LIKE  MESURING  SOME  HMMM>>
HIS DIVICES  IS  GIVE HIM DC  VOLTAGE  WHIT  AC   HMmmmmmmm ?AC SOME LIKE HZ  BUT IS NOT  HZ
ASK  @SPARK  HE GET SOME GOOD THINGS  FOR THIS  ELKTRONES
@ SPARK  WHERE IS  YOUR  ELKTRONES  WHERE YOU COLECTED <<OPEN YOU  ::)
@ FOR ALL MAN HERE  ASK   <<<WHAT WHILL HAPEND IF YOU HAVE VERY  EXPENSIVE   SPEAKER HO HAS  VERY  HIGH  SENSITIVE LIKE  130db SPEAKER
IF YOU PUT THER  SMALL  IN LIKE  I SAY ONE WATT INPUT MUSIC HOW WHILL BE THE LOUDS FROM HIM  ,, OR  YOU PUT LOW SENSITIVE SPEAKER  WHIT THE SAME  ONE WATT INPUT MUSC  HOW WHILL BE THE LOADS
