HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
MACEDONIA CD
HI
@LONER
you are ood think yes   secondary coil  is  the MAGIC
I HAVE ALL READY TOLD  IF YOU  MAKE STANDARD TOROID COIL  <PRY  SEC  COIL  >>AAND PUT  TE  MAGNET  THERE  AS  LIKE ME   THE  OUT   POWER  WHILL BE  GOING  DOWN
IF  YOU  MAKE  LIKE ME    THE  YOUR TOROID SEC. COIL  WHILL BE PRODUCED   MORE   OUT V  AND  A   WHEN YOU  PUT  THE SMALL MAGNET
I HAVE TOD  THAT   THE SIMPLE TRANSFO    IS NOT FORK   JUST LIKE  MY TOROID
IF YOU  SEE THERE  OUT HZ  IS  OT LIKE  PRYMARY COIL FREKFEN   <<<WAY>>
MAGNET IS  ONLY FOR  INCREASE  AND  TO TUNE  EXSACTLY    FREKFENCY   OF RUNING
MY   ATHER  PROTOTYP  NOW  IM  WORKING IS  MUCH  BIGER  ABOUT  6"  DIAMETER AND  I HOPE  WHILL MAKE   SOON   5  OR 6  DAYS  SOON
AND THAT    PROTOTYP  WHIL  I HOPE  FORK LIKE THIS""""""""
""""""......    <<<<<<  I WHILL PUT  AGAIN  50 HZ  BUT  OUT  COIL  WHILL GIVE <<2400 HZ>>
FIRST my  test  has   whit  small toroid  has bing  <<50hz in   200 hz  out
the simple toroid  or  lets  say  pus  frek  you put  10khz  or  50khz  to in coil  again you can have the same  frek  to hte out coil  how is  in frek   sec. coil  has  the same  frek  as  prmary coil  THAT  IS  ORDENERY  TRANS   MY  DIVICE  IS  LIKE   TRANSFOR   BUT   NOT ORDENERY
IF  I  LIKE TO MAKE  ANTHER  TOROID TRANF..   I WHILL MAKE  I N THE SAME THING  BUT  WHIT   MANY  1000  FREKFEN  OUT  IF  I WHANT
LIKE  50HZ IN  OUT  5000HZ  MY DIVICE MY  PRODUCED  THE  FREK UP TO SPEED OF  LIGHT  ONLY  WHIT SMALL  IN FREKF .. LIKE  50 HZ   OUT  1000000  OR MORE
IF I PUT MORE AAAAND  MORE  OUT FREK  I  WHILL HAVE  MORE POWER  IF I LIKE   YES IS TRUE  WAIT MY  ANTHER  VIDEO CLIP   TO SEE  MY  BULB  NOW  I WHILL   BE  LIGHT  I HOPE >>NOT STRNG  BUT   MORE   POWER  IN THE  OUT COIL    MY DIVICE  GIVE  MORE OUT    ENRGY THE N   IN
THE IMPORTANT IS   THIS   I HAVE MORE TEN IN  ENEGY   YOU MAKE   AND  TRAING  TO MAKE THIS   MORE THEN IN
S.M  sid  his divices is not  free nergy divices   this  is mean  that  the s.m  is put litle in enrgy  like batery of <,pc>>  my  is  3 voilts
thanks  see  you   whit  beter  features   now    i ehill  give light  now  to see  you  beter  ;) ;) ;)
sparks
   Hi Mac!
        The trick is permeating the core so the hf spike ( kick)  excites the torroid copper instead of getting eaten up by the core permeability.   The copper electron dipoles chase the kick magnetic field response and the copper atom gives up some of it's mass into energy.  In essense burning the electrons.  This does not involve the neucleus magnetic dipole moments.
The ambient electro-magnetic field restores the potential energy of the copper electrons,  then you get to burn them again with another kick.  The limiting factor will be how fast the backemf, which in this case is the only emf,  can restore the copper potential energy.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
22vision
Hi everyone,
I am new to the forums, well not new but I just registered. I have been
Reading all this information for a few years and now I have a scope and
All the testing equipment I need to start working on this little wonder!
I have a military background in electronics and I have access to a Lab
If I need.  Most of my efforts from now on will be on the TPU style device.
Just wanted to say Hi all and I am determined to find the answer here, I am
not one to give up easily as I have been told.
Now to the other stuff Loner I am getting similar results as I can clearly see there
Is something else to this to make the freq increase on the sec I have a bunch of
Different windings that I have tested and they all do something similar.
MAC is the core Air or you using metal in the ring with different sections as in your
earlier posts?
I am going to run some tests with some wire I have alum stranded copper and steel
I am going to use the same lengths and wrap each type on copper Iron and steel
And see if there is any difference in what type of material I use!
Any more help would be great MAC! Are the sec windings vertical or horizontal
To the primary or neither figure 8 maybe with 2 rings, at this point it is anyone?s
Guess I will just have to test and see but the core material would be very helpful in
my testing!
If I do figure this out I will post it ALL for free as that?s what this forum is all about
FREE to the world and I strongly believe in that.
~Vision
ramset
22vision   welcome we need good people    you definitely sound like one  and over here your with the best of the best  Chet
Thanks Grandma
MACEDONIA CD
hey @ new
how  you  have  see my   in this forum  im   i like to ansfer  way  you have  pick  me  for   test my divice  <<HMMM  >>YES    YOU ARE  I THING  IN  THE RAID   ROAD
you have  say  you have  posibilyty  to  make   test   whit  help  of   you  work place  / ,<my english is bad   but   im traing to   tapening beter >> :D
OH  YOU ASK  HOW IS MADE <,YES IS  TOROID FERITH CORE >>AND   NOW I DONT LIKE TO ANSFER  HOW IS MADE THAT TURNS
BUT I ONLY  TELL IS THAT <,THERE IS PRYMARY   AND SECUNDARY COIL     <,PICK UP COIL  >..AND  ALL THAT  POINT HERE I  ILKE TO  SHOW  IS  THAT SMALL PERMANENT  MAGNET  IS INCREASE THE   V  AND  milli amps  all that is   mesuring whit   load  resistor  12 ohms
the point  i put   50 hz and i have   200 hz   only whit toroid i have that increase the frek..
SOME GAYS  SAY TO ME  YES  THAT  INCREASE  IS FOR THAT RESONANCE CAP  IN THE PRYMARY COIL
THAT WAS THE REASONS  WAY IS INCREASE THE FREK.  UP  TO  200 HZ
                     I SAID  THIS  THE CAP IS  FOR RESONACE   ONLY THAT   BUT   NOT FOR    FREKFENCY INCREASE
ALL THAT STUFF IS   THE COIL THERE   NOTHING MORE    +  PERMANENT MAGNET
WHAT I WHILL SAY  IS  I NOW   MAKE  ANTHER  TOROID  WHIT  I HOPE  TO HAVE   2400 HZ  ONLY  WHIT  50HZ IN  TO THE PRYMARY  COIL
AND  THEN  I WHILL SEND I  SOME  BULB  HOW IS LIGHT   ;) ;) : ;) 8) 8) 8)
