HHO Boost Project 0.1
Started by readyakira, November 08, 2007, 06:36:23 PM
readyakira
I'm new here and must say this forum seems to have me hooked!  I have been thinking of making a H or HHO boost for my truck.  Last few nights I have found myself falling asleep while trying to absorb so much info!  So if I may I would like to ask a few questions.
1) What form of generator seems to be providing the best results so far?
2) Could someone help me with making one?
3) I notice alot of talk of a tempurature problem.  Would a second cell, and a few thermostats to turn them on/off help?  I hadn't noticed any mention of thermal protection.
I found the site thru zerofossilfuel's you tube and his generator looks simple yet productive.  Zero, have you tried applying the pulse form I see talked about to see if you can drop current draw and still obtain the same yeild?  Most sites I have seen talk about putting a booster under the hood, but why not in a trunk (or in my case the bed of my truck)?
So the other night I got the idea to make a simple one of my own and with limited supplies I bought some stainless steel cable (it said it was stainless at least).  I took a canning jar and made a cross shaped piece of plexiglass to fit just inside the bottle.  I wraped it with the wire cut in 2 pieces and spread them about 3/8in apart on a spiral to the bottom.  filled it with water and some baking soda and viola! with 12v applied I was able to make some gas.  I ran it thru a bubbler and vented it to the atmosphere.  Although I was making gas there was little production for the 12v 2amp draw I was using up.  So I know I would need something much more efficient.  Any help would be appriceated here.  I have very little science knowledge although I do seem to pick up on it easier then most.  I haven't found anything I couldn't do with a little direction and I am determined to not let this one get me.
Anyways great site!  I see much future in the work you all are doing?
Rosphere
Welcome to the forum.  :)
Try not to get so hooked that you quit or loose your job.  :(
Please post some pictures of your work.  8)
Please do not get upset if it seems like folks are not responding right away; this is a part time gig for most of us,... except for some of us.  Some of us are actually building things and can not be on-line all the time.  I will drop out shortly to finish winding that Rodin coil on which I have been working.
Please rename the title of your thread to something more applicable to your work or design; something like, "readyakira's HHO Boost Project," or something along those lines, would do in a pinch.  Most folks here might not take the time to click on a "New here" topic, much less respond; you caught me on a good night.  :-*
Be informative, try to be kind, and have fun.  :D
readyakira
Thanks!  I will post my 2hrs slapped together first attempt soon.  I just need to find a good place to upload the img to.
hansvonlieven
G'day readyakira,
Look at the page you post from, at the bottom you will see Attach:
Just click on browse, locate the image you want to send on your computer, click on it and You will have your image right here in the forum after you post.
Hope this helps
Hans von Lieven
readyakira
ty did not know I could do that.  I will have to call the misses and have her bring up my card reader here to work.
EDIT: This is the quick made spur of the moment electrolyzer I had made.  The misses laughed before I made this...
