Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
Nali2001
Hello and thanks for the reply.
Hmm you say "390vac @ 880Hz" any data on the amount of watt?
Another thing I'm curious about, does the device 'weakens/eat' the magnet?
And can we expect an updated construction manual or maybe plans about the
radical new version he was talking about, the one that has no resemblance with
the meg anymore (and no longer needs the magnets..?)
Anyway I hope this device does not go down in to silence like so many
other free energy related devices. He was also talking about joining up with
partners/investors what's with that, will he still be making public statement/plans?
Or is he just busy further developing the original design.
I'm very interested in the unit so please don't let it die out.
Thanks,
Steven
arinaya
I don't have any data on the current or wattage output, but have asked Jim for this and will let you know if I hear anything. A generic soundcard such as he is using puts out no more than 2W RMS, as far as I know. I am not sure how accurate the voltage reading is at 880Hz using a normal multimeter, but with the new unit he is lighting up full-size fluorescent tubes "brighter than I thought they could go", which you certainly can't do with the 1 or 2W of power that a soundcard gives you. I am pretty sure the new unit he has built does not use the magnets, at least I know he has found them unnecessary when using Audio input; also he has eliminated the phone jack from the design and has been experimenting with different placements and windings of the feedback/resonance coils. As for his partnerships I cannot say, but don't think they have gone anywhere productive as yet.
What's interesting is the optimal frequency is fairly sensitive: a difference in fractions of a Hz can cause huge jumps in output voltage. This is not just acting as a transformer, something else is definitely going on. I have suspicions that golden mean harmonics are involved, as the ratio of first and second primary coils is very close to the golden mean (an extra 9 wraps on the smaller coil would pretty much nail it). Obviously this is speculative at this point, but would make sense in light of Dan Winter's theory of extracting electric power from the local gravity well using golden mean recursion, etc.
I am planning on attempting a reproduction of Jim's design with a few modifications aimed at getting more current at the expense of slightly less voltage output. I'd like to use as few high-voltage components as possible while still getting useful power output. Also am planning on rectifying the output to Direct current so that more reliable readings can be taken. At this point I am targeting the design to something like 24vdc with multiple Amps of current (this is typical of a solar panel/deep-cycle battery setup, for example). Time will tell if this is feasible using the present design. Initially I probably will not include the logic circuit mentioned previously, just a simple variable frequency oscillator (manually adjusted) and hi-gain audio amplifier, something comparable to a soundcard, only much simpler, and isolated from any significant source of external power. If the design seems viable I would add in the voltage detection/regulation and automatic frequency adjustment and other goodies that would make this a useable device.
That said, it is going to take me some time to get the funds and materials together, and to find the time to invest in building and tuning the device. I'll try to keep folks informed as there seems to be some interest; if there are others who wish to experiment with this I would definitely be interested in sharing findings, design ideas, etc. Just let me know. If this design is going to go anywhere, it needs community participation; Jim seems to be at the end of his rope, but has given us everything necessary to develop the technology further.
Arinaya
Nali2001
Hello,
Well, you can also light a fluorescent tube by rubbing thin plastic sheets on them. This is of course very low watt.
Damn, if he builds a unit without the magnets... that would be even more amazing. (an over unity transformer)
Is there any clarity on the windings direction yet? Please explain a bit more what type of winding/numbers
of coil would be ideal for golden ratio. Tesla also said (so they say) "To let 2 coils "work" together the must
be of the same mass" (yes mass) It also should be possible to rectify the ac output to dc (capacitor/diode)
and maybe have a more reliable measurement of the voltage/watt.
Is Jim's situation really that bad...? It is really incredible that those independent free energy
inventors/workers seem to suffer somewhat the same fate. I'm glad I don't live in the USA.
What are we goin to do about this...
Steven
arinaya
500:309 would be pretty darn close to golden mean. I'm not sure if this asymmetrical coil winding plays a huge part or not in the performance of the unit, but I suspect it does, and have a soft spot for the golden mean personally. Jim has indicated to me that he winds the coils all in the same direction, but that he tried winding in opposing directions and it didn't make any difference. I don't really see this as a transformer, as the operative principle is Resonance. You will not understand it if you think of it as a transformer. The mass of the coils does seem to come into play, as the first and second units he has built use different wire gauges and different ranges of resonant frequencies have been observed. He also recently had a "skeptic" perform some tests with a proper RMS meter and an oscilloscope. They measured 0.5 watts of audio input, and 268 watts of electric output. Jim figures that with a better amplifier circuit driving the unit to saturation, a higher input/output ratio will be possible. I agree rectifying or at least regulating the output is one of the next things to do. Please note that neither Jim nor I are calling this a free energy or overunity device, although within the limited scope of conventional theory it might appear as such.
Regards,
Arinaya
Nali2001
Thanks for the fast reply.
Yeah I know... 'free energy' does not exist. There will always be 'a' source (zeropoint/ether/orgon/whatever)
But these are sources we consider 'free'. Although who knows what will happen when the worlds starts using
devices which extract vast amount of energy from the zeropoint/ether field. In my opinion it just might give some
negative results as lowered 'life energy' in the area of the device (presuming that we as living beings also
use the ether field in someway) But if you believe Tom Bearden the Zeropoint field energy is so immensely fierce
that the energy draw of the entire world would be totally laughable.
Could it be that the material of the core itself is very much responsible for the output.
(I don't know if crystal material is actually in the core material) But there might be a connection with
resonance/(harmonic)frequencies and crystals. Also the minute frequencies and vibrations might trigger
the crystal material and correlate to the Casimir effect. So it would be an interesting conclusion if the
HOPE unit would work (to some extend) using standard laminated silicon steel (stator/transformer steel)
or ferrite. (would also be much cheaper than that nanocrystaline material) Although the higher eddy currents
and/or core hysteresis would possibly eliminate the effect.
Are there any strange effect noticed with the HOPE unit like loss in weight or sub ambient operation or glow.
And the generated power, does it have any correlation with time reversed 'cold current' (the non shocking
counterpart of 'normal' current)
Thanks,
Steven
