Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
BushWacker
Hi FreedomFuel,
    I'm glad to see that you've found evidence to show that this is possible and I also agree with you that we can't make any claims of OU until all test results are in. I've got my best HOPE unit in the hands of the one person that I know who has the knowledge and experience in electrical engineering to do these tests. The calorimeter test is one of the tests that he told me he planned on doing. I've been waiting three months now for this guy to get busy with the unit that I sent him but I don't think he has done a heck of a lot of anything so far and I'm beginning to wonder if this guy was the right choice to choose as a business partner. The current model is basically the first working example of an initial theory that I put to the test and I believe that the design will most likely change as more information is gained over time. The example of the piezo-ceramic rod/bar that you pointed out is helpful to me and I believe that as time goes on we may be able to find much better materials and designs which will make the current model look silly by comparison. Hopefully others will gain interest from the evidence that we are finding and sharing here to invest some time and research into all of this. My gut feeling is that we need to look at combining piezo reactive materials such as Barium Titanate, Lead Zirconate Titanate, Lead Niobate, and perhaps even simple crushed quarts with high grade ferromagnetic materials to see if we can improve the materials that we currently have to work with. I suspect that if we can use various frequencies to induce a much stronger initial electrical reaction in a material, use that reaction to create an electromagnetic reaction, and add the copper coils to magnify that initial electromagnetic reaction with proper harmonics we may really be able to induce such a device to true OU. My intentions are not to try and sell people HOPE units but to try and point out the possible chance that most have been overlooking this type of approach to alternative energy technologies. We've got a long way to go yet but I think we've accomplished a good deal so far just by pointing out what we do know to date. Thanks again for that info FreedomFuel. I will send the link to our EE.
Cheers,
Jim
BushWacker
Original HOPE Generator Instructions
Now available in .PDF format.
Click on attached file to download.
Cheers All,
J.D.
Dansway
Hi,
This may have been covered, but what are the differences between the HOPE gen and Bearden's MEG?
Thanks,
~D
cverr
I'm e newbie in this forum and this is my first post and it will most probably be the only.
I've been reading on this topic for the whole evening from soon this afternoon.
Here are my observations:
1: you say that you do not feed your system with AC but with sounds.
What are sounds if not AC.
AC means alternating current.
An audio signal is an alternating current. Thus, you feed your system with AC.
A signal generator is a device able to provide alternating singnals of variable frequencies.
2: You said that your system has lots of energy but what is energy?
Energy in electricity is measured in terms of power and power is the results of voltage multiplied by the current.
However nowhere you gave an idea of the power delivered by your system other than 1000v at 2 amps which is 2kw.
I'm rather surprised by this when all you've been able to make your system is to turn on a few small fluorescent tubes.
Is is very easy to light uu fluorescents and being a ham radio since 35 years I know what I'm talking about because when I was younger I used to facinate my neighbors by lighting a fluorescent in my backyard with no wire connected to it. The trick was that before to go out, I used to put my transmitter on the air with 100 watts in the antenna and I knew that all I would have to do would be to come under my antenna and lift the fluorescent in the air above my head while I was under the antenna and that's it the fluorescent would glow.
Anyway, a fluorescent the size that you have doesn't use very much power and in the worst case, 20 watts or so would be sufficient to make it glow.
I would have been realy impressed if you would have connected a high power appliance and make it work to its full potential but that was not the case.
I'm not trying to say that you're a liar or anything alike.
However, to me you're just a poor guy who has not the slightest idea what he's doing and playing with.
By reading your information, I found that the ratio of your transformer is varying between 6 to 15 according to the number of turns of the numerous primary coils wich are ranging from 200 turns to 500 turns while your secondary coils are of 3000 turns.
Thus it is realy easy to go to 1000v with such a ratio because in the worst case, all you have to do is to provide a 100v signal to the 300 turns input coil and that's it that's all you will get 1000v at the output.
But it is not because you have 1000v that you have energy!
With a few miliamps all you can do with 1000v is to kill some moskitos hehehe :)
Besides, I remember that you mentionned that you could get 1000v at 2 amps at the output but you also said tou you couldn't even light a bulb with such a power.
C'mon man, try at least to agree with you own sayings. 2kw of power could easily turn on 20 bulbs of 100watts at their full capacity.
On the other hand, I'm extremely doubfull that your secondary coils could sustain 2amps with the size of the wires that you've used which is number 27 or 29 If I'm I remember.
Fisrt of all, there are no wire of such size like #27 or #29. The nearest is #28.
It could have been possible to sustain 2amps with secondary coils wound with #16 or #18 wires but I don't think so with so small wires such has #28...
The fact that appears more and more as an evidence to me is that your system delivers very very small power and it explains very well why it doesn't generate heat. There's no heat because there's no work accomplished by the load, that's it, that's all. By work I mean power. Power can be in the form of watts or in the form of HP. If your system would drive a 20amp motor at 100V then it would deliver 2kw of power when this motor would accomplish a mechanical work that would use all this power not when the motor would spin freely unless it would be a very very big motor needing such a power only to spin at the idle (without doing any work).
I'm sorry If I nmissed a post where you would have said that you powered a 2K electrical applicance for hours because if it would have been the case then your system would have generated heat and a lot of heat as a matter of fact becuase if it would have generated 2Kw of work it would have also generated 2Kw of heat and as a result your tansformers would have been gone in smoke because the size of the wires of your secondary (output coils) are just too small to support such a power.
The conservative rating of #28 wire is about a quart of an amp thus I realy doubt that it could sustain 2 amps at 1kv
The only thing that is clear to me is that your system is realy far from being a MEG.
Regards.
Kator01
LancaIV,
I did research in DPinfo and found the patent DE3900890 has been cancelled. See attachment.
Do you by chance have a copy of this Heyer-Patent ? Is he willing to cooperate and  reveal his technique ?
Thank you in advance
Kator
