Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
0 Members and 18 Guests are viewing this topic.
4Tesla
I edited my earlier post.  I don't think the second circuit will work.
Thanks,
4Tesla
Motorcoach1
@ Bentzer hahahaha ( the Edison way ) now thats funny I was thinking on the barriom farrite if you put a secondary winding on it and used it as a pump , mmmÃ,  ( arm Chair ) the pump recharges the cap - diode is needed
4Tesla
@btentzer
LOL.. My ideas are "The Edison Way" also.. but admire Tesla, hence the user name.
4Tesla
Bruce_TPU
Quote from: Motorcoach1 on November 27, 2007, 08:26:38 PM
@ Bentzer hahahaha ( the Edison way ) now thats funny I was thinking on the barriom farrite if you put a secondary winding on it and used it as a pump , mmm  ( arm Chair ) the pump recharges the cap - diode is needed
Hi Mike!
That is a very good idea and will be my third and last series of test's tonight.  A good idea indeed!   ;D
Thanks!
Quote from: 4Tesla on November 27, 2007, 08:34:53 PM
@btentzer
4Tesla
Yep, try everything under the sun and see if it lights!  LOL
I ran my first test of the secondary fed back to the anode side of the LED, no diode and no extra time.  36 minutes 52 seconds.
I am now running the next test with both leads, no diode.  Will let you know.
Holiday Cheers,
Bruce
supersam
@MANNIX, AND ALL,
has anyone heard of the recall on christmas wreaths?  it appears the iron wire that they have been made with have been coated with "LEAD"  to prevent oxidation before they were coated with plastic.  i wonder, what lead might add to this wire?
lol
sam
