Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
0 Members and 37 Guests are viewing this topic.
4Tesla
Thanks Joe,
That is a very strange circuit!
@all
The simulator didn't handle inductor/transformer coils well, but still worth the download.. very cool simulation of basic circuits!  This free version allows up to 25 components and has a lot of advanced features.
Edit:
@hakware
No luck?  Try with the original circuit by adding the trigger coil instead of the resistor at the base of the transistor.
4Tesla
4Tesla
My copper magnet wire came.. now just waiting for the toroids!   8)
4Tesla
Grumpy
        -Frank Edwards
Bruce_TPU
Quote from: Localjoe on November 29, 2007, 12:30:11 PM
Good odd ball refrence i found that design looks similar to stiffler's circuit just because of the coil ends... figured it might be helpful conceptually
        Joe                      http://leedskalnin.com/Magneticinductionclip.html
@ All
Did you notice the  Iron wire he used on his coil?   ;D  That is soon, going to be a test for me with this circuit, I promise!  Iron wire wrapped toroid.
Holiday Cheers,
Bruce
Localjoe
Thanks for checking that out folks i figured it would be useful, when the time comes if anyone has a free moment we need a little help in the earth battery thread in the sense that we now have readings of 1.4-1.7 v and about 2.3 miliamps of current its constant and our electrodes are seperated to the point where redox isnt taking place but there producing a little power.  We were wondering if we could design a micro tpu or something similar to make better use of the energy were recieving.  So if anyone has a free moment it would be appreciated just check out the earth battery experiments thread.  Im working on replicating your micro tpu and ive got a few transistors here that i just cant find part numbers for them for specs so im tinkering. Computer psu that are old or what not are great source for big toroid ususally :)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
