Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
wattsup
@btentzer
I think CTG Labs is right. I saw the same thing with my CBC as mobius just makes a short. You have x volts coming in but most is consumed by the mobius looping leaving not enough for the led. Did you try increasing the applied voltage but put a resistor before the led if you do this since it will blow.
I don't think mobius is useful here since it will cancel the field especially is the winds are one on top of the other. You need the field to impart magnetism through the ferrite, back and forth to the trigger.
Mannixs' design is somewhat mobius but the coils are not over each other. This may have a different effect.
I just got myself one good sized transformer and will try this on my Mini TPU circuit. Just by pulsing 3 volts DC on the 110volts primary and releasing sends sparks out about 2 inches from the spark point. Never saw that with the regular toroid. This transformer has a lot of mass and I want to see how it will react to the circuit. Will let you know.
4Tesla
Bruce,
Have you tried 2 cores like in the graphic?
4Tesla
4Tesla
@plengo
Have you done anymore testing with you rechargeable battery circuit?
4Tesla
Bruce_TPU
Hey guys,
No I haven't tried this on two separate cores yet.  That will be for another day.
I had my circuit, as shown in the schematic several posts back, except I wound over the bottom windings with two top windings.  Each winding having two ends.  I then hooked the ends, crossing in the middle with two IN002 diodes.  NONE of the new winding wires were attached anywhere on the circuit.  Circuit runs fine, but no extra time gained.  I reversed one of the diodes, and the LED would not light.  I then removed the diode, and the LED starts to blink, without the cap needing to be recharged.  Somehow, the second windings stopped the flow of current in the windings underneath.
On a side note, my son's light sabre broke beyond repair this morning.  I slid out the 21 LED stack and plugged it into the circuit,  ;D all 21 blinked away, with no power hookup.  I went to recharge the system and time it and when I touched my leads to the battery, some of the LED's glowed then smoked.  Yet one LED is fine.  Any thoughts on why a stack of 21 would possibly have some fry when 9volt is touched?
Holiday Cheers,
Bruce
4Tesla
Too much current.. I isolate the cap from the circuit when I recharge it.
4Tesla
