Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
@ Sanmankl
Here is my latest schematic update.
Holiday Cheers,
Bruce
4Tesla
@plengo
I made the following circuit on a simulator based on the circuit linked in my previous post.  It works in the simulator, but didn't build the circuit on my breadboard to test it.
To your specs that you need.. 3v in, 2.7v out, and 18.3mA with a duty cycle 90/10 (90 on / 10 off).. to switch to 10/90 (10 on / 90 off), swap the 1k and 10k resistors and for 50/50 use two 10k resistors.  To change the frequency change the size of the caps (both same size).
4Tesla
Two Transistor Oscillator
Edit: Don't need the diodes
sanmankl
Quote from: btentzer on December 09, 2007, 01:23:17 AM
@ Sanmankl
Holiday Cheers,
Bruce
@ Bruce,
Thanks. I'll give your circuit a go. See if I can do more....?
Cheers, sanmankl
plengo
@4Tesla
what software are you using for the simulator?
Fausto.
4Tesla
@plengo
The diodes aren't needed in that circuit... cleaner output.  Increase collector resistor value to 220 ohms to keep under 20mA.  Here are the links to the free schematic and SPICE simulator software that I am using.
I found this free software for making schematics:
http://www.expresspcb.com/
I found this free SPICE simulator:
http://www.analog.com/en/content/0,2886,0%255F1206%255F162825%255F0,00.html?ref=ASC1285
4Tesla
