Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
Quote from: 4Tesla on December 11, 2007, 10:13:07 PM
I don't have my toroids yet.. but have been playing with LED circuits and just verified that running LEDs in series takes less current to run.. each time I add another LED it takes 2-4 less mA to run the circuit.. I have reduced the current by 10mA by just adding more LEDs in series.. it doesn't seem to effect the brightness of the LEDs.  I found that running the LEDs in parallel doesn't reduce the circuit current.  I would have thought since you are lighting more LEDs that the circuit current would go up and not down.  Does anyone know why it goes down?  Something to do with the diode voltage drop?
Thanks,
4Tesla
@ 4Tesla
Thanks for that info.  I now have placed four of my LED's in series.  One blue, one red and two yellow.  I will eventually have all blue, rated 2600 mcd in brightness.
@ Sanmankl
I have an interesting experiment going on right now, last one of the night.  I realized I had made an error in how I had the diode I had mentioned to you,  hooked up on the board.  Tested it hooked properly into the board and the circuit did not work at all.
So I wondered why I had gained time when I had improperly connected it to the board.  Then I realized it was acting as a resistor there.  So I removed it from the circuit and placed a resistor in it's place.
ALL of the 4 LED's are flashing about three times brighter.    I also have the two control wires hooked very different.  (each set of leads simply goes to a small ceramic cap) So, over the next several nights, I will go through my arsenal of resistors and see which one gives the best time.  If none, I will remove it and put it back the way it was.
Then I will unwind these control wires, and rewind, using one turn connected to itself, with unshielded silver plated wire, and going to a cap.  I will do this twice like tuning forks.   ;D  So, no lack of experiments here for the next several days.
Holiday Cheers,
Bruce
4Tesla
Bruce,
Your welcome.. did that increase run time?
Thanks,
4Tesla
sanmankl
Quote from: btentzer on December 12, 2007, 12:09:04 AM
Thanks,
4Tesla
@ 4Tesla
@ Sanmankl
Holiday Cheers,
Bruce
@Bruce,
This is interesting development indeed. I would need to read this post carefully (not that your description is bad but English is my second language) so that I really understand what you are trying to say.
Thanks. sanmankl
wattsup
@plengo
I took a 9 volt battery that had 8.45 volts on it. Connected it to a 110 volt light bulb for two days. No, the bulb did not light. With the load on, the voltage went down to 0.008 and stayed there. When I remove the bulb, the voltage jumped to 0.346 volts and started slowly going up in .001 increments. Left it for a day and a half. Checked the voltage just now, 3.207 volts steady. lol
Zinc and carbon. I wonder if the LTPU wall material could be made of such a mix of material. SM already said it once, "if this was a battery, it would be a very big battery".
@EEers
If any EEer on the board can go through a step-by-step explanation of how EMs original circuit works, especially when the transistor base is activated and what actually happens in that instance. In layman terms. No reversed bias lingo. lol
Bruce_TPU
@ 4Tesla
I am not sure.  It was very late last night when I found this.  Tonight I will begin proper testing and see if there is any merit to it
@ Sanmankl
Here is my circuit as of last night.  I just need to figure out a) what size resistor at the question mark will increase my time, or b) what resistance value was my diode I had there giving that increased my run time?
Holiday Cheers,
Bruce
