Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
@wattsup
I know. If you connect to an LED it will keep it on for days and days. Mine was on for more the a week. Very interesting and when connected to the LED it will stop at 1.605v and run .1ma current. Thats why I was saying I could not "kill" that battery no matter what.
Now, I experimenting with another circuit (4 tesla switch) and I ran into something even more interesting. I was able last night to have 2 batteries connected, one at 8.5v and the other one was "dead" (like 2 or 3 volts - the voltage that comes back to) and I let it run the circuit for the whole night. Results were impressive. The dead battery is now 7v and the source battery is STILL the same 8.5v no change. And in this circuit there is an LED in series with ampmeter and another series of LEDs in parallel also running.
Tonight I will try an experimenting replacing the batteries with Caps. Here why I am posting this: The circuit is very similiar to what this mini-TPU is also but I think the secret is in this 4 tesla circuit ( or at least part of it - the proof of concept) and if we could have 2 caps one charging the other and running the load there we go we have the mini-TPU running forever!!!
As soon as I come home I will prepare the schematics and post it and where is the source of info for the 4 tesla switch proof of concept that i am working on.
Fausto.
Bruce_TPU
Quote from: plengo on December 12, 2007, 01:49:08 PM
Fausto.
@ Fausto
Now that sounds like a brilliant idea.  I look forward to seeing the schematic.  If you could peek up at my circuit and suggest where and how to add that second capacitor, that would be great!
Holiday Cheers,
Bruce
starcruiser
Quote from: btentzer on December 12, 2007, 07:51:32 AM
@ 4Tesla
I am not sure.  It was very late last night when I found this.  Tonight I will begin proper testing and see if there is any merit to it
@ Sanmankl
Here is my circuit as of last night.  I just need to figure out a) what size resistor at the question mark will increase my time, or b) what resistance value was my diode I had there giving that increased my run time?
Holiday Cheers,
Bruce
Bruce,
When you hookup a diode in reverse it can act as a varicap depending on the reverse bias, so you will have resistance and capacitance as well depending.
Regards,
Carl
4Tesla
@plengo
Please also post just the 4 Tesla circuit you're using... is this one of N. Tesla's circuits or one I posted?  Confused because of my user name.
Thanks,
4Tesla
Bruce_TPU
Quote from: starcruiser on December 12, 2007, 05:25:45 PM
Bruce,
@ starcruiser
What I actually did was place the diode in the same line on the bread board as the power.  So the power kept flowing, right under it.  A novice's mistake!   ;)  LOL
@ All
Testing resistors and looking for results.  I love Plengo's idea.  We need a way to add that idea to this circuit.
Holiday Cheers,
Bruce
