Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
@ Wattsup
I will do that and post it this evening.
@ All
I have been experimenting with a lot of different things.  I have combined two other oscillators to this circuit, including the one that plengo is working off of.  A lot more to go.
I have also tried some things out of a Tesla patent drawing.
Three Strange Anomalies:  (To me, anyway!   ;D )
1.  Exact same run time, with one Red LED rated at 1.7 volts as three Blue LED's in parallel, rated at 3.7 volts.
2.  When the LED goes out, there is still some voltage left in the cap.  Short the cap to 0.00 volts, and give it some time and the voltage will come back up to .048 ma at the cap and entire circuit.  No matter how many times you short it, it comes back.
3.  Wrap loosely a one turn piece of silver plated wire around the wound toroid, and join the loop to it's self.  Touch the battery and the LED burn brightly.  Move the circle to the trigger side and the frequency increases greatly.  move it around and I can adjust the frequency that the LED blinks.
I have changed out the 1000uf cap for 250uf.  The time is exactly 1/5th!  So I am happy with that, for it increased the number of tests I can run.
Holiday Cheers,
Bruce
AbbaRue
Hello everyone, I am joining this adventure too.  I have been following the videos all month.
I also build one of Dr. Stifflers circuits and had 40 blue LED's lighting up using 12v 22mA..
I ordered some Litz wire to wind my own coil for his circuit, hope to get it soon.
I am planing on using ready made transformers for this circuit though, to see what results I get.
plengo
FYI,
I built a second circuit based on the first one but this time I used another coil that I had. It did not work. Interesting enough!!!
It must be related to the coil I or may be my second mosfet is not working right. I will buy a new one let people know if it will work. I am also working on a version where "anyone" will be able to use out of shelf parts and make it work.
Fausto.
Groundloop
plengo
@Groundloop
good job man. You are correct. This is the cigar box, but did you notice on the pdf about how they measured and that Brandt and Bedini tried step by step of each node (transitor, coil and batteries) and he had the 2 batteries and the second one was charging from the first and the whole node was only the 2 batteries, 1  transistor and 1 trifilar coil?
That's what I am playing with. Not the whole circuit yet. I noticed that with just what I presented, which is a ultra-simplified and modified version of one node, it will recharge the battery.
Your circuit could work and is probably a more modern design of the whole switching stuff. But we need to test one node at a time before trying the whole circuit, which will probably not work, and than we will have to hell test it. Do you see?
One more point: what I end up with is recharging the battery. You see, when I see anything from Bedini where he uses a transistor and a coil I never look at it as if it was just a transistor and a coil. That guy (Bedini) is a very smart fella. He sees things and design things in a way that it is not that abvious and neither trivial. Just a transitor and a coil can do so much that we dont know. My circuit variation is a clear demonstration of that (if my circuit is indeed recharging the battery).
Fausto.
