Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
Quote from: wattsup on December 20, 2007, 07:59:59 AM
@btentzer and @all
Good going.
I went to my EE surplus place and spent a good 20 minutes rummaging through a mixed transformer bin and found this small transformer ($1.50) with two primaries and two secondaries, all isolated.
Used one primary and two secondaries.
Put it on EM's classic circuit.
Gave it 9vdc for three seconds and it ran and ran and ran for a whooping 9 minutes 10 seconds. For the first time, I could see it flicker fast although very low intensity, but 9:10, wow, that's my record. It lit for longer but the LED was really really low.
I can try with both primaries in parallel or in series or in mobius.
There is potential here since having this working circuit, I can now test with adding an aerial plate on the positive and a ground plate on the negative. Or other tests. Great.
This is great because it gives me a standard and any tests deviations will help me learn. Just great. I put a photo below.
@btenzer, how did you start your non-battery trials. I used 9 vdc for 3 seconds.
I think this would have to be standardized also.
(snip)
@  Wattsup
Congratulations on a working circuit!   That does give you something to work with, for sure.
My base time was holding the battery to the circuit for 20 seconds and then release.  It was just a time I had chosen, and stuck to.
@ All
I measured my battery this morning, the one plugged into the circuit, and it reads 7.16.  I am not going to drain it, for I want to see if it will charge past yesterday's high.
My other battery has been draining on a 30 ohm resistor, now for about 18 hours.  The voltage has already climbed, by itself, to 3.40 volts.  I will wait until I see it hold steady before testing it.  If it will hold steady.
Holiday Cheers,
Bruce
plengo
Guys this is as simple as it can be. This first picture is the one that I have total success. It is now 8.18v. Six LEDs up and running non-stop for what, now, 4 days? and voltage only increasing.
The other replications are still in no good progress. So no need to fuzz anyone with wrong designs.  But this one is working good. The coil I think is the special stuff that balances out. It is a 315ft magnet wire, 23 and 18awg. Bifilar. I said that already a couple times. It is as simple as anyone can wind a wire into a spool. The spool is 2.75" width, 2.5" height and 1" hole. Plastic. No core just air. Just take two wires and put them together and wind the baby until your 315ft goes out, simple. If you need more info goto the yahoo group of Bedini_Monopole3. They have in scruciating detail how to build one.
The mosfet is only helping me to get to the right voltage and balance. I tried a miriad of transistors and mosfets and the IRF510 is the one that works the best. You will have to touch the gate a few times until this gets to the rigth place, where the LEDS will be about 1/3 lit and will run and the battery will charge. There is a video at youtube that shows that (http://www.youtube.com/watch?v=LXtafVgJW_M).
The second picture is the osciloscope at any of the LEDs terminals. It took me a little awhile to get it clean and steady for me to be able to take the picture. That answers hartberlin question. Tdiv = 2us and TVdiv = .5volts.
Everything that I am doing is just playing with that design and testing the hell of it.
Fausto.
Honk
Sorry for interrupting but have any of you realised that all you do is to play with Back EMF.
Back EMF cannot provide overunity and it's well understood and is just a transformation of voltage and current levels, not energy.
Magnet Power equals Clean Power
plengo
@Honk
I think you are almost right Honk. You see, Bedini has demonstraded the opposite (at least it is my opnion). BEMF is just as conventional EE as it can be, BUT its effects on batteries is not.
Look at Bearden and Bedini explanations why the BEMF (or gradient as Bedini calls it) works at http://www.icehouse.net/john1/index101.htm.
Fausto.
Honk
If there's magnets involved there might a possibility to harvest some of the forces from this source.
Like the bedini motor, but without magnets there is no OU from Back EMF, but I'm still sceptical on this matter.
Back EMF is simply: Input Energy - Losses = Output Energy in reverse polarity but no gain of free energy.
The losses can be pretty big if not taken into account, e.g saturating the coil core, copper losses, eddy currents, and so on.....
