Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
@spacemonkeyjazz
oh, I know that con. I bought it and it is totally a BS. The coil needs a lamp wire going throwgh it while the lamp IS RUNNING. In other words it is only a toroid coil reusing energy from a running lamp via magnetic induction. Off course as soon as you put a load on the coil you are going to use more energy from the power feeding the lamp.
If you look carefully the video you will see that there is a black wire with 2 turns inside the toroid, that's the lamp wire.
Beside, his "plans" were in 4 pages print out with capital letters, bad English and no way you can rebuild the thing on his instructions. It is an absolute scam.
I would even advice that you to remove the link from the thread and post something in place explaining the edit.
Fausto.
zon
hi, all
This is a my first experiment, build charging alkaline battery 1.5 V with source battery only 1.2V Nimh battery 900mAh. I don't understand why charging battery can be more voltage than source battery. Where did come from ?
zon
Note: if you take out the charging battery, the led will on (lid on)
(sorry for my poor english)
Starlight
Tonight i have done my replication of Mircro TPU, and it works! I've recorded video, you can see it on youtube, http://www.youtube.com/watch?v=xav6hfAD3zg
i used 2 MegOhm (2 x 1MOhm) Resistance, ~1 microFarad (directly 920-927 nF). Impulses flashing 2-3 times per second (2-3 Hz)
Sheme from this topic. This work took about 3 hours :) Thank You for Schematics, and sorry for my English )
По - Русски было бы проще  :D
sn7401
Quote from: Starlight on January 14, 2010, 07:08:50 PM
Согласен, но блин, надо учиÑ,ÑŒ англиский....
а неподскажиÑ,е, виÑ,ки обмоÑ,ок и можноли заюзаÑ,ÑŒ вмесÑ,о биполярника полевик, напрмер КП505/BSS295?
Starlight
sn7401,
СмоÑ,ри видео на ÑŽÑ,убе )
Я использовал Ñ,,ерриÑ,овое кольцо из сÑ,арого блока пиÑ,ания оÑ, компа, выпаял и снял обмоÑ,ки. ПоÑ,ом взял провода совеÑ,ские сÑ,арые, они из аллюминия и намоÑ,ал биÑ,,иляром около 12 виÑ,ков, они ажно друг на друга залазили. Плюс, упроавляющая обмоÑ,ка из меди с Ñ,ого кольца, около 5-7 виÑ,ков. Разницы не замеÑ,ил. ОсÑ,альное по сÑ...еме. То же из блока пиÑ,ания, смоÑ,рел по даÑ,ашиÑ,ам Ñ,ранзисÑ,оры и коÑ,орые подÑ...одили сÑ,авил. Ð'роде полевики не рабоÑ,аюÑ,, я всю веÑ,ку пракÑ,ически прочиÑ,ал, Ñ,ам где-Ñ,о об эÑ,ом говорилось.
