THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Vortex1
S9 you said:
QuoteI am heading a £2 billion development fund which will include all advanced systems including the new research from John Hutchison as re manipulating radiation levels in the ocean .....
Well that's very impressive.  ;D Best of luck with your new position.  Are you hiring?  There are a lot of people on this forum that might need the work.  ;)
Ok so now I know who your are talking about, it's Dr. Steven Greer, for some reason I kept thinking Dr. Gree.
That' clears everything up!
Mr Vortron
Vortex1
Dear S9
It has occurred to me that drilling a hole into the variac core will short the layers of the  sheet metal ribbon tape that is wound to form the core. This ribbon tape is normally insulated between layers with a varnish to prevent shorts and eddy currents that would develop, creating extra heating in the core and thus reduced efficiency.
An alternative more benign approach might be to just glue a wire to the face of the core ribbon tape with some conductive epoxy.
Just thought I'd pass that by you for comment.
BTW, what do you intend for this third wire? Can you post a complete schematic of the proposed hookup?
Hopefully with labelled terminals?
Vortex1
http://www.mag-inc.com/products/tape-wound-cores
Vortex1
Dear Sequental.9
You said:
QuoteREAD THIS  5 TIMES AND GO FIND A REAL PIANO AND FINALY YOU WILL UNDERSTAND !
Right now I'm up to 3 times but hope to get to 5 times, my eye are hurting and my glasses are not too good.
I have a small screen laptop and the print is rather tiny.
I will look for a real piano, but what would I do with it?. My flat is too small to fit a grand piano. I do have a bundle of piano wire salvaged from am old piano.
QuoteSo please add the 4 mm hole ASAP ! WHY DO YOU HIDE THE VOLTAGE RESULTS ? I HIDE NOTHING ! AND IS WHY I FOUND EVRYTHING... Quantum ballence ! Try it
Now that you have clearly explained it's requirement, I now understand the importance of the 4 mm hole and will drill it PRONTO. The only question is this: Is it a 4mm diameter hole or 4 mm deep hole. Whichever it is I will need the other parameter also.
Can I assume it is 4 mm diameter and 9 mm deep?
I will sleep well knowing I have been blessed with such a perfected vintage variac.
I thank you for the brief music refresher. The strings on my guitar are tuned EADGBE, but I sometimes use alternative tunings.
I am not seeing any voltage out of my variac and it has been running for days so I can report to you 000.0 volts. Honestly, I am not hiding anything. When it is hooked to the O Scope I see some small noise from a nearby fluorescent lamp.
Am I supposed to give it power? I thought the TPU gave out power?
Send the schematic with input and output connections and I'll give it another go.
Kind Regards
Vortex1
Vortex1
Quote from: Sequental.9 on September 14, 2016, 06:56:45 PM
How can it read zero volts if its switched on ? turn it round to its max position and what does it say ?
Only a well-tuned piano can locate the resonance in 5ths ! So you're in a flat but what about your workshop you said you had ?
You turn on the variac for how many days ? you stated only 60 minutes ! I am very sure you know what I mean and this little bit of pretending !
Its ok I have done what I came here for ! Good luck ! Buy ...
S9
Dear S9
The 60 minute test was for the temperature rise test only. The other test (according to the attached drawings) was not connected to the mains because I thought it was supposed to pick up some earth-moon- sun resonance.
Since none of the drawings you sent showed a mains input except an unrelated one, I assumed it was supposed to be in free air. The specific drawing you said to use was VOORTEXTESTS.png. (attached).
You said it was very important to drill a hole and attach a third wire, implying there were only two other wires, but this third wire was never shown in any of your drawings.
I will run the test again with mains input , but I have no idea what to do with the new third wire attached to the core. I will post the output voltage reading here.
Maybe it is very clear in your own head what you want done, but it is not that clear to me. Call me a dunce if it pleases you.
I'll give it another go and see what happens.
Have a great day.
REgards
Vortex1
Magluvin
Quote from: Sequental.9 on September 15, 2016, 07:45:44 AM
Now the video please ASAP ! Set up the small work space with camera from your phone not held by hand and take one step at a time up the north face of gravity and climb wit me to the top where we place a flag of freedom for all humanity !
Or get the fuck out of here !
S9
P S Do we have an agreement ?
Well that is motivating. ??? ;)
Mags
