THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
tinman
Quote from: Vortex1 on November 07, 2016, 03:12:12 PM
Tinman said:
When both end coils are energized at the same time,the center coil will have double the voltage across it to that of each end coil-if the turn ratio of all three coils is the same.
It will also produce twice the current to that which is flowing through each end coil.
Brad:
Will have to try your suggestion on the bench. Twice the voltage and twice the current is four times the power so should be easily OU. Have you already tested this? What were your results? Timing diagram?
Vortex1
No,i have not done such tests,the answer was more a thought experiment,based around an ideal transformer,where there are no losses.
Jeg
Quote from: Turbo on November 02, 2016, 03:26:16 PM
Next step you create multiple electron flows in that coiled wire.
In stead of observing only the electrostatic effect, you now start to see also the magnetic effects.
The fields generated bump into each other this causes the vibrating sensation in just the one wire/coil.
Hi Turbo. Do you think it is some kind of a beat frequency that takes place and transforms all these electrostatics in to a useful current? Is it a build up of a low frequency standing wave when some of its harmonics are being used?
According to your opinion, is this middle section coil of your design the multistrand one that Steve M. has used as a core to his device?
Thanks
Turbo
Quote from: Jeg on November 10, 2016, 04:41:36 AM
Thanks
I don't think so.
I always believed the beat frequency was the product of the difference between the higher frequency's.
Also that the beat frequency was itself very low and resonated with the large magnetic waves he speaks of.
There is evidence that he used a feedback mechanism.
uln2003an
@ turbo https://www.youtube.com/watch?v=gwJUN2iNBIk
I,ve been looking at this TPU for a while now, I still err
on the side of caution and believe it,s a probable scam,
I am willing to entertain the fact that it is legit and
doing so, break down the contraption to it,s parts, the
first are the two saturable reactor "like" cores in the
mid of the large one, I have seen this type of setup
before in everyday items in the form of a ground fault
protection circuit, it,s the heart of the protection
circuit, when one side is interrupted by a short to
ground this induces an emf in the core and the circuit
is tripped. pics below saturable reactor, tpu, and
ground fault.
some music while you build your gear
https://www.youtube.com/watch?v=_B789lus-JE
sm0ky2
According to Steven, the lengths of the wires and diameter of the coilings are designed with respect to a harmonic of the Schumann/Earth frequency.
In theory, any regenerative impulse frequency harmonic will do.
For instance the 130Khz feedback signal of residential electricity.
The parallel windings not only drop the resistance and increase the current,
But the field around the wires is quantified, resulting in an increase in
Voltage and total power.
Without such considerations, many a transistor hath perished...
