THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Esa Maunu
Quote from: devilzangel on November 19, 2007, 11:53:08 PM
^^ you r kidding .. if you want to argue about the theoretics of the energy source of the TPU, it would be wise to leave politics out of it.  ;D But since you opened the door, i thought to add my 1bit: There are many reasons to why SM did what he has done and is doing what he is doing. I am very much inclined to opinionate that the incentive wasn't the furtherance of humanity; although initially it might have been. I am against the corporations and governments who have influenced SM into submission.
If the TPU did exhibit gravity (intensifying the gravity field around its mass), it would all of a sudden start pulling object towards it. This is NOT an observed phenomenon when viewing SM vids. SM would have mentioned it even if this aspect was minimal.
I am inclined to believe that the TPU does not operate along electro-gravitic principals.
devilzangel
Yes, this is not a political forum..
The reason, why TPU is not pulling objects towards it is because there are zones of gravitational time dilation, that are caused by vortex. The net drag effect is zero, both overpressure and underpressure areas of zpe exists. Even, if gravitatational net effect is zero, there is an increased inertial mass.
Esa
libra_spirit
Thoughts on theory
I believe that with correct set up energy can pop between any of the field forces. Comprehension will be the mastery of manipulation. I believe Bearden is closest in identification of time, as a C^2 energy, as is mass. Time is compressable and time flow rate is not fixed.
What this boils down to is the A vector potential, or the linear force yet to be defined and understood. It operates off the sides of a toroidal coil while all the magnetic field is contained within it. It is also termed as torsion and tempic energy by others, the field that can bend radiant light, and sometimes produce waves in the appearance of reality.
The toroidal coil is most mysterious in that with a single wire passing through it, an opened coil on it will shoot to infinity voltages and start to fry itself, yet a short on the winding will completely stop all power from developing. This is the CT in power metering circuits, and you allways keep them shorted until connected to the power meter, or you start to get the arcs we see in the videos of the TPU. These same arcs can shoot out of simple CT's used to meter 3 phase commercial power feeds. With the correct resistance they will operate as current transformers to meter the current in the feed wires.
Now we have a toroidal coil with iron core, and no external magnetic field possible, yet a wire looped through its center forming a wrap will develop a current appearing from the A vector potential, which is said to not truly exist and yet it must exist or the loop could not become energized.
Tesla patents:
I have yet to find a Tesla patent that uses only copper wire at 90 degrees and no iron core? There will be a large difference in the effects to the EM waves if iron is present or if not present.
The TPU is not an AG device, probably because it does not run cold like the Sweet device that did loose weight. The TPU is tapping the hot or outflow side of the A vector potential. It generates electric current that would be called DOR by those in the Psi device field.
This is [Deadly Orgone Energy] and they believe it is evil! LOL! But you must recall the microwave shielding some have resorted to using to avoid headaches. Whenever iron receives sharp square waves there is a microwave danger from ESR and from fast domain reversals. The downside of Beardens MEG unit, possible sunburn as well.
To get the high energy from a collapsing field, you need an iron core. Remove the iron and move to copper copper, all you get is the spike on connection and disconnection, both seem about equal until you configure to the TPU and cause one to be offset. Thus the DC source is from the wiring setup making one spike side taller.
The spike is C velocity E field, and is not current. The secret is how to get the unit to make the current using the super high E field spike, and this was verified over and over in a great many devices.
Now if we are to believe the latest testimony, there is no electronics and no spikes from square waves. Only a reed relay to switch things as the magnetic field rotates around coils in a quad arrangement on a circle. Hard to believe and yet the Hubbard device sounds similar. Just the correct coils and a lot of work to get them started. They would have to be tempic resonant coils and not EM resonant coils to do this.
Circular coils are similar to the Joe Cell layout and we see an energy coupling effect on the Joe Cells, where as long as the plates remain wet, the voltage is present. This indicates the voltage is being set up by the divergent radiant light field and not by any physical matter between the tubes. The geometry is similar, and you can see that the A vector potential or torsion that forms in rings around any one tube has a finite and exact distance necessary to effectively couple. These exact distances are being identified, for the Joe cells they are about .515" but this is a fractal and can be multiplied by 8 or divided by 8 and get coupling also. Otto verified only a certain distance between his CC coils, to find the optimal coupling for this A field energy. He never tried altering this by a factor of 8 but I would guess others will be present.
Tempic field, or A vector potential forms in geometric rings of fixed distance where it will focus, and between these points is spreads to form a wider diamagnetic field. Distances are charted by sensitives to this field, and form a matrix, or grid system. Rods of special length are moved to exact distances and the energy is felt to couple between them strongly. We have yet to start winding coils on these rods and try pulsing them to observe the effects, but the effects of bending them into circles has been identified.
TPU cooling:
Coils that produce cold energy have been found to date with intresting windings over large plastic tubes.
I have no doubts that the TPU can be modified very slightly to mix in some cold energy. Also if one is bold enough to make the feed coil of scalar or partial scalar design, they will still produce the E vector pulses on the 90 degree CC winding with a total current shut down of any possible heating on the input coils. Scalar coils run cold. This limits heat to the output collector but may create other problems? Using totally scalar cancelling input coils would be mastery, as now extremely small energy would be drawn on the input of a system.
Where does the energy come from:
The A vector potential, a linear or Radiant Light path, set into a circle creating a convergent or divergent node at the center. Very simply, a tempic field gradient, altering the time flow rate from center of the circle to outer ring of the circle. The tempic gradient polarity will depend on the voltage gradient. Same model as a Joe Cell. Same model as gravity in the earth. I would guess that the TPU being a hot outflow device creates a slightly heavier gravity field then normal. Has any one ever weighed these in operation? I would expect an increased weight may be present. If the unit ran at room temp then there would be a reversal of the A vector pulsing, headaches, and same weight. Cold, then a lowering of gravity.
There is also the possibility that the mass of the wires is changing as well. This energy flows out of the strong force area of the atoms as they regulate themselves while reacting diamagnetically to oppose the electron shell activity. It is Radiant Light and follows the straight path through space being bent only by gravity and not by EM. It forms the A vector potential. [Best guess]
Concentric rings at resonant radiant light distances, with positive at center and negative on outer ring will form a gravity node at center like the earth or a natural atom, reverse the voltage and the field reverses to a cold anti gravity field [Joe Cell] negative at the center positive on the outer ring. For the TPU to run fully cold it would have to be running in this mode. The toroids inside would receive the negative charge and the outer system would be operating positive to this. [observations from many devices]
Dave L
otto
Hello all,
@Dave,
a long time ago I measured the weight of my TPU at a low frequency at around 5Hz: the weight was changing, going up and down but I missed to measure the weight at high frequencies.
I also managed to have 1 totally cold control coil and 3 hot coils, or 2 cold coils and 2 hot coils but I forgot how I connected them!!! It was a very long time ago. It depends how you connect this coils. Of course, it looked like the air around this cold coils was also cold. It was last summer and it was really hot. I have to say that I couldnt measure the temperature around my cold coils becasue I dont have the equipment.
I also tried to use only 1 output wire connected to the bulb. Like an Avramenko plug. It was only a little bulb. Almost no current flow from the power supply but a nice light on the little bulb.
Otto
aleks
Getting cold may mean that free particles are tapped into the device and form new matter. That's why thermodynamic energy (kinetic energy of particles) is lost - it is being enclosed into matter. It's strange that devices gets lighter, though. I would expect it to become heavier when it is run cold.
When device gets warm it means that particles are freed from "matter cage" and the matter disintegration is occuring (particles are released from the matter with some initial kinetic energy). In these conditions devices should have lesser weight as reduced gravity field should be one of the conditions for disintegration to be possible.
If this system is valid, one of the ways to run device without overheating or overcooling is to combine both processes in a required proportion. It's best to place the overcooling coil in the center of the grounded metal sphere so that particles that are freed from the overheating coil are tapped back into matter by the overcooling coil, or go to ground. Both coils will be producing usable energy because the reason of overheating is that some freed particles are not going into load circuitry wire, but float around. In the case of overcooling particles are going into matter, but due to existence of their flow some of the flow energy can be taken to do usable work.
DonEMitchell
Newbie to this forum, old dog to a few, hard time growing up with my head, please let me share personal theory.
TPU energy source per an insight = the nuclear inertial resonance against its own electron cloud tension from within --a non-quantual continuum mediated by electron shell geometries-- with many nuclei coupling into the resonance via cross-field cancellation ...loosely based on Frank Znidarsic's theory paper, 'The Control of the Natural Forces'.
When the resonant geometry has an overall system symmetry, various effects may emerge, per theory: chilling, then deeper resonance leading to destructive voltage spikes if imbalanced electromagnetically.  Fine balance in geometry affords fine control, deep resonance is potentially dangerous, last words could be, "Oops!"  Hyperbolic pulse trains afford controlled ramp and de-ramp.  Modulo harmonics afford control of the tiger by the tail = inertial field, temporal field, and ample E/M control, by influencing motion of standing waves across the resonant envelop.  This is all speculation based on personal theory.
Per theory, the scalar energy field is very much involved with broadcasting the nucleo-sonic attitude as a 'field apparent', and this is more an intuition and not yet up for words on demand.  The ultimate energy source is the expanding Universe, with temporal differential providing power amplification, proper... very much a Newtonian violation.
After years of waiting to find a working theory to base experiment upon, I be ready!!!
Simultaneous cancellation of capacitance and magnetic fields producing a toroidal rotation of 'nothing' = poly-phase pulse-driven bifilar Moebius edge coils on a torus surface.  Control is very much dependent upon Golden ratio, Fibonacci numbers, and heterodyned harmonics interlocking as charge compression (gravity) in the torus center.
Thanks for listening, wanting to open source the project as prudent (safely).  Cavey calls this a super-TPU design.
DonEMitchell
stranger in a strange land
p.s. Gots lots o' pics of families of bifilar Moebius edge coil geometry illustrations.
