THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
david lambright
otto!...i like the way your mind operates!! there are many answers that are being found by us...i have found that the energy created by the TPU is the same type of energy created by a toroidal PMH....i am x-tra curious about the cold coils you describe...i think that you might want to check out this thread..   http://www.overunity.com/index.php?topic=9603.msg270280#msg270280   ...i have felt weight anomalies with my devices for a long time but the visible radiated wave is really something to see...my videos do not do justice...do you see any thing strange around a TPU?...david
DonEMitchell
Hello,
@ everyone
I'm a newb, short attention span, sensitive, vulnerable, and low in the EQ.  Over blessed on the IQ... seriously... frustrating... I can see it but can't explain it... been trying.... here's another attempt to share...  remember... I am a stranger, and don't know anybody to offend, and I'm certainly not attempting to compete... but share what things have lodged in my bwain.  [What follows is fast and loose.]
The source of the TPU energy: the vacuum, or space, or subspace.
Why?  Because the universe is expanding, and there is a trick to open a crack to allow energy into our systems.  The principle of the trick is a transition from harmony closed on itself (like a torus), to an open energy system (like a cylindrical electromagnet).  In a quantum transition (the stuff that makes electromagnetics), the atom goes from closed harmony, transists through open radiating change, then re-closes (with more or less energy).  That's the principle anything to do with quantum events acts on... and EVERYTHING is based in the quantum scale, and the quantum is energized by the power that is expanding the universe.
From one moment to the next, the expanding universe isn't just expanding, but accelerating while doing so.
R.N. Boyd, Ph.D --one of the few out-of-the-box quantum physicists, agrees: A few milliseconds ago, there is a different density in the fabric of space than there is in the right-now.  Robert's advise was what lead Podkletnov to try an experiment that bent steel beams with a gravity-beam from a spinning superconductor.
Q: How to tap the energy differential of the varying density over time of the vacuum energy? (The hint is in the sentence.)
A: Be at two places in time with a harmonic envelope that is harmonic across a span of time... and make that span a very very short distance in time, as the vacuum energy is a tremendous reservoir of energy, and you don't want to tear a whole in the universe and vaporize the neighborhood (kidding sort of).  A successful tapping into the vacuum energy tends to sometimes run-away.  One in Europe (private group) had to be dynamited to shut down.  The Enola Gay pilot slammed his hyperresonator with a stick when it arced over the knife switch to keep running, and both took out the local neighborhood power which was draining into the dimple in time the devices made.
Q: How to dimple time?
A: Compress charge.
Q: How to compress charge?
A: Create a geometry that forms an antenna of 3D shape that creates the environment for the higher harmonics to fall into a conjugate attraction.  Requirement: the harmonics need to be a part of a harmonic envelope... when so, the harmony is one entity, any part effected affects the whole of the harmonic wave group.
Q: What is this geometry?
A: One may be a Rodin Coil, which is an entangled helix.
A2: Resonant half-wave rectifier bridge pulses through a loop against a superconductor torus ceramic that has a bucking permanent magnet against it (Superconductive Antigravity Engine, Hidefumi Kobota)  This is the same effect at the quantum level, which acts as a macro-quantum scale in a superconductor.
Q: How to create the effect without superconductors?
A: Resonate with the matter-wave the way superconductors do.
Say what?  OK... this does get involved, and matter-wave resonance on an amateur workbench could get scary.  Be careful!
Examples of danger:
1) Brian Prater was hospitalized for a month when he touched a hissing, silvery bead that came out of his hyperresonator when he shut it down.
2) A friend told me of his friend in Sedona, AZ that thought a vacuum chamber would make his experiments safe... wrong.  The hyperresonance engulfed the room, as he watched.  It backed him into a corner and messed him up.  He was in the hospital for three days from the field effect.
What I'm discussing is the super-TPU that everyone wishes to understand.  The tests I've seen -all of them- are more like cargo cult than science, meaning, we don't know what we're doing yet.  But no doubt many of us have many clues, me included, and wouldn't it be nice if we could all meet at a brain-trust-retreat for a week?
This is an attempt to help... based on patterns in the alphabet-soup of endless theories... the consistencies are sleuthed out.
The Otto device is a many-to-one transformer, and the lead in the solder was the active device. The Otto device needs more turns, but of a proper geometry... flash over-voltage surges are a sign that the lead atoms polarized by their positive nuclear fields (oblation polarization).
A morph of the late Otto's insight, and the entangled helix of the Rodin Coil will begin to get closer, without superconductors.  There are many degrees of torus knots.  All indicators point to one with a neighboring numbers from the Fibonacci sequence.  There are many to test.  I'm leaning to an 8:5 torus knot, as 8/5 = 1.60, while the golden mean is 1.61803...  This leads to a small phase-wave that should be correctable with the proper application of pole precession (magnetic flux density wave in the torus).  If the phase wave isn't nullified, the standing resonance needed will jump between loops in a dissipative harmony-breaker.
Rodin, Otto, or any other device I am privy to, requires yet that one needs to know how to manipulate the frequency to create the harmonic environment -1st effect, and then -2nd effect: twist a knot in the resonance... that knot evolves through time slower than do we (except for that part of our neurology that uses a dimple in time so DNA can resonant with some part of eternity).
Twisting a knot required a deliberate and precise application of non-sinusoidal prime drivers.  This is a combination of toroidal rotation only possible with an entangled helix on a toroid (Otto's was never entangled) and magnetic density precession (pole wobble) above and below the torus.  The missing phase of the Rodin coil may well provide the rudder for the precession.  It is the ratio of the pole-precession and the toroidal spin that creates the magic.  Now the scene is set to begin to accumulate energy in the torsion of the wave-group.  That trick is borrowed from sonar technology, and is also the trick that enables the resonant envelope to be ramped-up or ramped-down... rather important.
Enough details... getting too long.  People... I have a deep yearn to pursue this research, and Mom didn't have any dumb kids.  Like a bobcat (my spirit guide) I can only socialize (like this) for a short spell and need to get back into the woods.
By now you either hate me or love me, or weren't interested enough to get this far.
The perfect team for the laboratory in the deep woods:
* An antenna specialist, versed on fractal antenna and wave harmonics.
* An open minded quantum physicists (I know, they don't really come in that flavor).
* A power engineer, able to work with the new blazing fast gallium nitride power transistors (12 volts rise-time per nanosecond, up to 55 amps per device, and parallel with inherent load sharing without disturbing speed, and $5 bucks each as bare silicon dies (tiny), two to seven hundred dollars each if mounted in military packages.
* An EE versed in programmable arrays, micro-controllers for loading the arrays as controlled by a user interface it communicates with, and circuit board fabrication.
* A rich benefactor (kidding, sort of), but a "Scalar Technologist Gild" is a thought --membership funds shared resource.
The super-TPU consists of 3-phase coils of a carefully dimensioned entangled helix on a torus, all three on the same torus, and a super-fast, low-voltage, high current (10 volts, 500 amp surge for a split second) phase-angle and duty-cycle adjustable variable frequency pulse supply.
Live long and prosper,
AZDon
"Refrigerators R Us" (because the super-TPU will turn cold while it is making electricity at the cost of the resonance.)
Links?  I got links, notes, and lots of graphics with POVRay.  Golden mean, Fibonacci, platonic solids, natural hints, etc.  Please just target your question, and hope I haven't ran for the woods.
Oh!  I forgot... to resonate with the matter-lattice electronically requires a frequency that is dependent upon the scale of the resonator, and for a typical desktop size device with a one-meter wave-length at harmony, would be about a megaHertz, give or take, and also dependent on the atomic weight of the resonant core material. [Frank Znidarsic, 'Control of the Natural Forces']
pix
@DonEMitchell
"The super-TPU consists of 3-phase coils of a carefully dimensioned entangled helix on a torus, all three on the same torus, and a super-fast, low-voltage, high current (10 volts, 500 amp surge for a split second) phase-angle and duty-cycle adjustable variable frequency pulse supply"
That's what I an talking about from quite of a while.
TPU has 3 coils spaced at 120 deg on the common torus made from conductors.Coils should partially cover their neighbour coil to get smooth rotation of B field. Those coils should be driven like 3 phase motor- impulses are spaced 120 deg so as a result you have rotating B field alongside torus.
"Squeezing electrons out of the conductor like you squeez water out of the garden hose".
This is also Tesla related, and even enchanced by small modification :-)
regards,
Pix
Magluvin
Hey Pix
So lets say we just had 1 core(of wire) and 1 coil wrapped on 1/3 of the coil, for basic purposes, if we pulsed the 1/3 coil, it squeezes the core charge in 1 direction or does it ooze from both ends?
Or can we have 60 smaller coil divisions, with  the first, forth, seventh.... in series, second, fifth, eighth.... in series  etc.   and each gang around the ring has 20 coils, 3 gangs.  But I suppose that the freq would have to be higher than just 3 coils. 20 times higher.
hmmm  If a pulse causes a directional flow in the core wire, then why not 1 coil and pulse it?  But if its a bidirectional squeeze, we would never get anything from the core unless it was tapped inside, in the middle of the so called control coil, where the squeeze outward has a center point.
So it would make sense if 3 coils, slightly over wrapped, would continuously move this squeezed area around the core coil, and how fast you pulse them in series will determine how much the core can deliver in current.
Seems a lot easier than combining freq harmonics into the pixture. ;]
Mags
ramset
Don
Let me know if you need a good cook?
Sounds like a fun time if you don't send the kitchen into a worm hole!
Chet
Thanks Grandma
