Thanks to ALL for your help!!
Plasmatic Induction - Power for your car and house?
Started by Liberty, November 15, 2007, 10:21:02 PM
Liberty
Interesting article about a form of electrolysis that runs on water and uses carbon rods, that claims to only need to be refilled once a year and it can run a standard internal combustion engine on hydrogen gas...
Here is the link:  http://www.peswiki.com/index.php/Directory:Akvo_Energy_America's_Hydrogen_Generator
Anybody have any knowledge about this device?
Liberty
tao
After looking at that page, I would say that he is simply using a known idea...'Bingo Fuel' ala http://jlnlabs.online.fr/bingofuel/html/bfr10.htm
That is the reason for the carbon rods, and the reason the Akvo inventor calls it a 'Plasmatic' induction. This is exactly what the Bingo Fuel reactor does!
So, if I had to guess the Akvo process:
Akvo modified a Bingo Fuel reactor, and developed a way to continually make sure that the carbon rods at a certain distance from eachother (a mechanical process).
The reason that they say that you can refill the thing once a year is because:
"The BingoFuel Reactor produces a mixture of carbon monoxide and hydrogen (COH2) and this gas can burn very cleanly in oxygen or air, and so it can be used as fuel for an internal combustion engine. When burned, COH2 produces carbon dioxide and water vapor, so it generates very little, if any, pollution to the environnement."
So, Akvo is simply using a modified Bingo Fuel setup, they devised a way to keep the carbon rods near eachother continually, and they recycle the combusted COH2 gas which turns to water vapor when combusted, so this water vapor can then be piped back into the tank and return to the tank as water.
JL Naudin already showed a video of his Bingo Fuel setup SELF RUNNING. The COH2 gas from the Bingo Fuel was powering a Honda generator and the Honda generator was then powering the Bingo Fuel reactor, a SELF powering setup. What is the fuel then you ask? It's the carbon rods! AND 5 PARTS OF AIR
("The Synthetic gas produced at the output by the BingoFuel Reactor is not able to burn itself, it must be mixed with air in proportion of 1/5 ( one volume of synthetic gas with five volumes of air ). So, the Fuel mixture useable for an internal combustion engine is 6 times more than the gas produced. The BingoFuel Reactor is able to produce about 1080 liters per hour of Fuel mixture.")
So, this process has merit for sure, but it does CONSUME the carbon rods...
Yet, it also consumes 5 parts of AIR, so this whole process is CONSUMING AIR AND CARBON, just like the sun is to solar panels, air and carbon are to the Bingo Fuel / Akvo type setups... So, again, there is certainly merit here!
In fact, look at (Akvo)Hunt's own words:
"The process involves hydrogen extraction from water via plasmatic induction(SAME AS THE BINGO FUEL), a form of electrolysis. A small amount of electricity is combined with ordinary drinking water to release the hydrogen. Water from a reservoir tank is hit with electricity. A bright flash of light occurs(SAME AS THE BINGO FUEL) each time the electricity strikes. Within seconds, the hydrogen released causes the water in the reaction tube to bubble a few small bubbles at first, then a steady bubbling throughout the tube.
The hydrogen gas will be ported into engines, providing fuel. The system also uses reserve batteries and solar cells. Non-radioactive carbon rods are part of the system(SAME AS THE BINGO FUEL) that Hunt said will power a vehicle for 1 years on one fill up.(ONE FILL UP OF WHAT? CARBON RODS OR WATER??? I THINK HE IS SAYING THAT THE CARBON RODS WILL LAST FOR 1 YEAR...) Emissions from the vehicles are water vapor.(SAME AS THE BINGO FUEL!)
"There?s an additional process that doesn?t allow the carbon dioxide to be released(SEE IT IS THE BINGO FUEL!!! HE STATES WATER VAPOR ABOVE AND HERE HE STATES CARBON DIOXIDE, THOSE ARE THE ONLY TWO OUTPUTS FROM BURNING THE BINGO FUEL GAS COH2, SO IT IS THE SAME THING AS THE BINGO FUEL SETUP!)," said Hunt. "
In fact, this whole process dates back to the late 1800s!
"This device is fully based on the Hilliary Eldridge patent US 603,058 "Electrical Retort" granted on April 26, 1898."
http://www.google.com/patents?id=W8tSAAAAEBAJ&dq=603,058
Pirate88179
Excellent informations, thanks.  Once again, we have a technology dating back to the 1800's that we, as a society, are "rediscovering".  I appreciate you bringing this to our attention.
