Farnsworth Fusor and Multipactor
Started by Grumpy, November 19, 2007, 10:46:22 PM
wings
Quote from: ramset on March 10, 2011, 08:47:20 AM
Terbo
Quote:
Since the Meeks device outputs energy in the 4-8 MHz (HF) range, it could be used to operate lights and heaters directly.
Sir,
The Fact that this is solid science,and being done at "Amazing" levels[22,000 more times Out than in] dictates a much closer look for "US".
Your above quote  would be a great start [OU heater]!,Making a low vacuum tube seems very possible [Wings link above]
I have seen other members here that have beautiful examples[XS NRG]!
This specific material that enhances the "Bounce" or production of electrons "Seams" to be a secret?
I spoke on the phone with William Barbat  some weeks ago
and this Chemical [what he called it]was a problem for him,although he had figured it out and was going into agreements for production.
Can you shed any light on a replication protocol that would show OU at any freq?
Thank you
Chet
Terbo & Ramset
Electrical power from the plasma ?
http://jlnlabs.online.fr/cfr/ape/apenrg.htm
probably the same effect
with other results
http://jlnlabs.online.fr/cfr/lorio/index.htm
wings
Quote from: Terbo on March 10, 2011, 01:18:24 AM
@ramset
Thanks for the warm welcome.  I find multipactors interesting because it is easy to understand how free electrons from secondary emission can create real OU energy when accelerated in a potential field.  Additionally, it appears that the Meeks plasma multipactor being discussed is not too difficult to construct.  Since the Meeks device outputs energy in the 4-8 MHz (HF) range, it could be used to operate lights and heaters directly. Fig 4 in the patent shows how that output could be tapped.  The bigger problem, especially with the Farnsworth devices that output energy in the VHF and microwaves, is how do you convert the RF output to DC for transportation, and to 50/60 Hz AC for appliances?  Semiconductor power rectifiers required for this conversion really don't function well above about 1 MHz. Since the operating frequency of the Meeks plasma device is inversely proportional to it size, maybe one could build one large enough to run in the 100 KHz range where the RF output could be easily rectified to DC.  Any thoughts?
read The Super Tube Moray B.King - PCM part:
http://books.google.it/books?id=0RmkmrFxHM0C&pg=PA71&lpg=PA71&dq=%22the+super+tube%22+Moray&source=bl&ots=0rOGUKlrkV&sig=6UA4S52QSjdElnDEXD4pXXqlYf0&hl=it&ei=0Y8fS4WqO4St4Qb5n_zfCg&sa=X&oi=book_result&ct=result&resnum=7&ved=0CCoQ6AEwBg#v=onepage&q=%22the%20super%20tube%22%20Moray&f=false
wings
Electrical oscillations without employment of electricity?
"Generally the trend goes to ever smaller operating voltages. The processor in the PC runs today already with less than 3 V, and digital electronics aims on a long-term basis at the 1-Volt-Durchbruch. Also attempts with electron tubes are ever more frequently accomplished with small tensions. The absolute record succeeded to me now with a UHF triode PC86: A high frequency oscillator with an anode voltage of 0.000 V. This ZVO (zero VOL days oscillator) will surely revolutionize the technology."
http://www.b-kainka.de/bastel87.htm
with thoriated filament?
wings
Terbo
Thank you
Chet
related experiments:
http://hwlenter.mnsi.net/ARGON/ARGON1.htm
ramset
Wings
Very nice info!
So this goes OU !
@XS NRG Are you out there? You tried to share this once...........maybe twice before,it fell on deaf ears!
They say Third times a charm.......................
Please?
Chet
Thanks Grandma
