Meyer type WFC - from design and fabrication to test and development.
Started by Farrah Day, November 22, 2007, 11:55:54 AM
Super God
Nice setup you have there!  So what are you going to drive the cell with to begin with?
>9000
Farrah Day
Hi SG
While I have the materials to construct my full prototype, I've actually built a small test cell for some initial experiments.
The first thing I will be doing is a contolled experiment. I'll be dropping the test cell (unconditioned) into de-ioised water and comparing dc electrolysis against pulsed under the same conditions.
I expect dc electrolysis to produce next to nothing in terms of gas. If I get any amount of gas production from dc pulsed then I will hope to find out why, with my test equipment at my aid.
Farrah Day
"It's what you learn after you know it all that counts"
Farrah Day
Farrah Day
Farrah Day
As I'll be using a function generator to provide my pulses during testing, I don't need the 555 timer chips, just the transistor output stage to switch the power.
To this end I've attached a schematic of the output stage I'll be using. Power will be provided by my Farnell stabilised PSU set at 10 volts.
Farrah Day
Farrah Day
My power transitor output stage built and ready.  This output stage should be able to take the inductive load of a car ignition coil if I want to experiment with some high voltage pulses... but that's later.
Farrah Day
