swhich permanent magnet on and off
Started by gaby de wilde, November 24, 2007, 12:42:21 PM
gaby de wilde
Left is a primary axle with a magnet on top. Right is a secondary axle with a magnet on top. If there was no shield the secondary magnet would rotate along with the primary 1:1 With the shielding placed as illustrated (close to the domain wall a bit towards the primary side) the secondary magnet is is disconnected from the primary 2 times per rotation.
While the primary is facing the shield with both it's north and it's south pole (it's side) there isn't any flux propagated beyond it. Here the secondary axle stops and waits for the primary to move beyond this point. The moment the primary has moved beyond 50/50 induction the secondary will leap over the gap and catch up. The catching up power comes out of the magnet.
I can leave the primary in any position and it will just stay there. It's merely pulling the secondary into it's mirrored position when facing the shield. Should not be hard to test.  Just remember to place the conductor closer to the primary magnet.
I would like to get some feedback on this.
Conservation of energy talks should be addressed here  ;)
http://einsteinhoax.com
blog  | papers | tech | inventors  | video
Omnibus
gaby, can you show an actual experiment doing this?
CLaNZeR
Quote from: Omnibus on November 24, 2007, 12:46:41 PM
I will  ;D
I knew the Kiss Rig would come in handy again  ;)
12 different metal strips tested:
Soft Aluminium
Brass
Copper
Mild Steel
Magnetic Stainless Steel
NON Magnetic Stainless Steel
Galvanised Steel
Hard Aluminium
Phosphor Bronze
Nickel Silver
Zinc Plated Mild Steel
Zinc
Movie showing all 12 metals being tested.
http://www.overunity.org.uk/CLaNZeR-doing-Gabys-PM-switch-test.wmv
Cheers
Sean.
Omnibus
Thanks a lot, Sean, that was really interesting (and entertaining too--I liked the song). Do you have by any chance a piece of mumetal (Permalloy) to try this. Very efficient mumetal (the most efficient I've seen so far) is the part inside a hard drive with the neo(s) attached to it. Maybe you have an old hard drive lying around that can be sacrificed in the name of science?
CLaNZeR
Quote from: Omnibus on November 24, 2007, 02:48:31 PM
Silly question, I have stripped down so many Hard drives I have lost count. Will have a go at chipping a magnet off the Mu-Metal.
Also got some Meta-Glas that I can try http://www.blockemf.com/catalog/product_info.php?cPath=757&products_id=5114
Will get back with results.
Cheers
Sean.
