Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
Newton007
Ok, thanks, all these sites seem to work a little different.
I will look at the information.
Newton
Bruce_TPU
Quote from: Grumpy on January 02, 2008, 11:54:08 AM
Quote from: Grumpy on January 02, 2008, 09:57:54 AM
VHF band is 30 MHz to 300 MHz
So, why is everyone else that is working with "three frequencies" using frequencies in the kHz range?
Did SM not indicate that he was working in the MHz range by speciifying the tubes in his equipment?
This freq range is obtainable in ring resonators of the diameters that SM has shown.
I think the reason, speaking for myself anyway, is that the two very, very specific frequency's given by SM are in the Khz range.  His 35.705 Khz and 245 Khz.
I for one have always believed that the real power will come only in getting the three right frequencies.  He said there would be "some power", even if we did not hit the right frequencies.  IMHO we have yet to see that, even.
Perhaps 1 of his 6BQ7-A tubes, and used in an electron circuit that acts as frequency multiplication.  Thus in theory, one tube could produce the three frequencies and all the odd harmonics needed.  This would be easier perhaps to build, then three seperate tube oscillators.
I think the TV receiver circuit, in those 1958 RCA televisions, received for a millisecond, those correct frequencies, that SM alluded to, time and time again, in his letters.  When it did, all that power and no outlet, so boom, implosion.  Of course that explanation is oversimplified, but the jist is understood.  IMHO I believe that the 6BQ7-A was the culprit for the explosions and is why SM hinted to us that specific tube.  It is also still readily available.
innovation_station
starting now at the very beginning gets us to the end
;D
ist
Newton007
After reading the inventors notes, he seemed to make a point that several wires may be used in (parallel) although he did not seem to say that is how his TPU works. This may be a key of some sort. He may have done this.
I would like to hear any comments on this.
Remember he cut the TPU up to show people that there were no battery's inside. He would know where to cut as to not show the coil connection arrangements.
Here is something else,
Don't worry about the operation of the gas pedal if the engine won't even turn over.
  think this one of the reasons the coil part has no patents. How could you patent a few coils of wire with all the patents out there now that have all types of coiled wire in all kinds of arrangements? It would be tough, I know as I hold two patents, and was rejected on one and it was a real good design too.
I think the "secret" is the coils of wire and the correct Length. The inventor seems to hint at this several times. If my theory is correct, then it's just a matter of finding the correct Length of wire wound in a coil to show a voltage difference between each end.
I think he said that they "crushed" about 300 of these coils before they got a good one. So some trial and error is involved.
But it is just coiled wire, not a $10,000 computer or some other sort of equipment they were "crushing" up.
They did not say they crushed up any other equipment, that I could tell any way.
It is just my thoughts.
Newton
sparks
      Funny I was thinking about some AC power plants I used to work on  that used saturable core reactors.  The more voltage the alternator put out the less DC would be fed to the reactor which resulted in less field excitation of the alternator.  Great voltage regulator no ss no tubes.
They also use these devices in magnetic amplifiers.  Well anyway I went to a search engine and typed in saturable core reactors this evening and at the top of the list was this site called  www.tpub.com.    Coincidence I guess.
Divine inspiration less likely.  Well anyway the site turns out to be a great scource for learning about alot of different stuff.  It is put together I think for the navy or some military folks.  Worth looking at.  Easy for a builder to remember  TPUb.  Name even has one of the secret frequencies in it.
     Then tonight gets even weirder.  The post below by a fresh mind working on this site is talking about magnetic amplification and the tpu just about the same time I'm websurfing this site mentioning mag amps.  I'm logging off and heading for the hay before today starts moving into the twilight zone.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
