Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
EMdevices
"..The control wiring is vertically wound in several segments around each of the horizontal collector coils. Other control wires are wound around all of the horizontal collector coils together...."
Since control wires are wound, whenever we wind a wire round and round, it's what we would call a coil :)
I'm not sure why we are debating little things again.   We know the geometry pretty much we are looking for the frequencies now.   But you need to know the composition of the wires.   Horizontal wire is IRON, or some other magnetostricitve (and also magnetic) material.    IT NEEDS TO VIBRATE.
So why does it need to vibrate, just for the fun of it?
So it can cut through the EARTH MAGNETIC FIELD, and move ELECTRONS IN A WIRE,  "...THAT WAS USABLE ENERGY..."
EM
Grumpy
Guess they can be "run or wrapped vertically over the horizontal collector wires".
        -Frank Edwards
nightlife
 I am new but I think I was able to figure out how it works and where the energy comes from. I believe frequencies are the energy source and the magnetic field is the collector and the pulsing of the frequencies in the magnetic field is what is used to move the electrons in the wiring. I did find out that different frequencies require different wire or materials to get the best results. I did post these things in "Sparks New TPU Design" thread but the following is what I posted in that thread.
     Re: Sparks' New TPU Design
? Reply #16 on: Today at 02:29:59 PM ? Quote Modify
Here is some interesting information if not known already. I can see how this concept could possibly be modified to produce usable energy.
http://www.magnet.fsu.edu/education/tutorials/java/fticr/index.html
This information added with the information in the High Permeability Wires - 1936 Article thread,
http://www.overunity.com/index.php/topic,3747.0/topicseen.html
makes me believe this could possibly work.
? Reply #17 on: Today at 02:51:03 PM ? Quote Modify
Here is some more information that may help.
Because lightning strikes are pulses, they contain many different frequencies and because the Earth is a resonator it takes these harmonic-containing spikes and filters them into multiples of the Earth's resonant frequency. Therefore, frequencies of 7.8Hz, 15.6Hz, 23.4Hz etc. are all supported by the Earth's resonator.
http://www.angelsuniverse.com/schumannresonance.htm
__________________________________________________________________________________________________________________
I think that if anyone is attempting to build this, they should read those articles in the links I provided. The same should go for those attempting to build a solid state design. I am also starting to think that a electron is nothing more then a pulse of frequency in it?s own magnetic field. I am also starting to think that the earth is a positive and the atmosphere is the negative.  Let me also add this idiotic theory, everything evolved from the compression of frequencies.
Maybe I am just insane in the membrane. LOL
BEP
From a NASA Tech Brief:
ââ,¬Å"A whistler presents the curved signal and is the result of a ââ,¬â,,¢spheric that has been modified during its journey to the receiver. The curvature indicates that higher frequencies of the whistler reach the receiver before the lower frequencies. This is a property of the propagation of low-frequency radio signals in a magnetized plasma (a gas of charged particles with an imbedded magnetic field ââ,¬â€ in this case, the magnetic field is that of Earth). The whistler waves propagate more or less along the magnetic field, and the longer they propagate, the larger will be the difference in arrival times between the high and low frequencies.ââ,¬Â
@Otto,
The current distance between my ââ,¬Ëœcollectorsââ,¬â,,¢ is 44mm. Not because of what you said ââ,¬â€œ because there is where I get the best interaction between the coils and the 1800 Hz cyclic variation between the 3kHz and 4.8kHz vibration.
I suspect: each layer has a different velocity factor. The bottom coil being the slowest because it has the combined magnetic fields of all three ââ,¬Ëœcontrol coilsââ,¬â,,¢.  That would mean the bottom collector would have the lowest resonance while the magnetic field of the control coil is applied.  Since the bottom collector has the most magnetic field applied it means this collector would have the highest ââ,¬ËœQââ,¬â,,¢.
nightlife
I just found this video using TPU as a search and clicked on the most recent and found this next video link. It looks as if I maybe right but I can't say how they built theirs.
http://www.youtube.com/watch?v=vsZ0EC2VeJw
