Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
Bruce_TPU
Quote from: nightlife on December 13, 2007, 05:28:43 PM
I just found this video using TPU as a search and clicked on the most recent and found this next video link. It looks as if I maybe right but I can't say how they built theirs.
http://www.youtube.com/watch?v=vsZ0EC2VeJw
His name is Jason.  LOL   ;D  This is an old video of a test of Otto's and Roberto's ECD.  It IS NOT what you think.  The video, that is.
Keep searching, but not youtube, please.  Watch SM's video's for clues.  That may actually help.
Holiday Cheers,
Bruce
nightlife
btentzer, thank you for confirming that it is not what I was thinking it could be but the concept still could hold truth as to using two frequencies, one being a lower level the other, instead of just one. It would make for a interesting test to see if it is true. Not only that but maybe even adding two or more frequencies to the test would be interesting.
joe dirt
Hi Nightlife  :)
yes watch the video,s and LISTEN also, there are a few clues in the audio of each, especially in video
  #5 http://video.google.com/videoplay?docid=-5483558279656482347&q=steven+marks&total=5657&start=0&num=10&so=0&type=search&plindex=4
Dirt
joe dirt
and if you simply want to light bulbs the cheap and dirty way is to do this:
The really poor-man's version of a scalar system that attempts to get some power into the field uses the energized parallel wire concept. Looking at the spool of wire on the right, that happens to be a spool of 250 feet of #20 gauge lamp-cord, the end of the spool of wire is shorted out. The application of a sufficiently low voltage, but high amperage current of either AC or DC is applied to the free end. CAUTION: High Voltage KICK BACK can happen when the source of voltage is removed due to field collapse. Typically a variac is used to drop the line voltage to something that doesn't blow up or smoke out the coil. Alternate methods have dropped the variac, and instead of the short, placed a 250-500 watt light-bulb (fixture) in its place. The spool is made of plastic
but it is not an amp that runs with gain, it just looks like it does.
all of this is from the bob dratch site: http://bob-dratch.org/#Part1
nightlife
joe dirt, thank you for that link, it did make for a very interesting reading session. Although quite long, LOL.
I am not exactly sure how to take a lot of what was said but I will go back over it and research it more when I have the time.
I did go back over those video's you gave me a link to. I have seen them all before but I didn't know they were all linked together. Yes, they do all have to do with frequencies as I thought they did. Based on that, I was probably on the right track with my assumptions of the design a lot of people are trying to duplicate. Thanks again for that information.
As for the scalar effects, did you research these accusations? If this is truly a hazard, then I would have to say that it cant be that bad do to all the technology around us being used 24/7. Then again, I haven't researched this yet to say one way or another and again I must thank you for providing me with that information.
You have to excuse my ignorance do to my lack of education but please note that I am problem solver in the automotive field with 27 years experience. I dropped out in the 9th grade to work and I have never went back to school. I do feel that I have a pretty good sense of common sense and that is really about all I have to offer except for life experiences. I own several company?s including a auto repair company and a large upscale restaurant and night club.
