gravito-magnetic ( Imris Pavel patent CZ9401781 !)
Started by Drannom, December 02, 2007, 11:33:51 AM
Drannom
Thank you Broli !
i appreciate it very well !
now i am satisfy, as much as we can from a simulation, anyway only experiment can put it forward...
to understand the variance just imagine infinite number of balls then you'll realise that is worst, and few balls will be not enough smooth, you may be rigth who knows
here again the Imris Pavel wheel
that wheel can be the easy way to produce OU ?  i dream to reproduce it to test it
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
How is the Pavel wheel suspposed to work. It's just seems covered on one side which magically makes the magnets forget about each other. I have my own idea but it might be the same. The idea I have in mind is to have a half circle shield on one side.
Edit:
abit like this...
btw I also discovered bad engineering in that gravity model. the forces on the left side are not radial THUS they produce a negative torque. This shouldn't be the case if they are radial. So this is my bad. I'll correct this. Here's a shot of that.
As you can see those vectors are not pointing to the center as they should.
Drannom
Thank you Broli !
the Imris Pavel gravito magnetic wheel is pretty easy to understand !
magnets loose strength between 2 metal plates at the left, and regain all power in air at right !
Imris Pavel done this one in 1995, only the picture give all we need to understand
Next week I will come together with Dr. Pavel Imris ,
but the gravito-magnetic wheel is actually not our target !
The listed e-mail is , I think so,from an CZ-engineer - but not the same person !
Sinerely
            CdL
Quote from: lancaIV on June 21, 2008, 06:28:37 PM
Sinerely
            CdL
p.s.: the visit let show the "fruit" of our co-operation, not directly gravitational-but also,
       by the end, rotational .  As real/physical object.
