nelson camus' reed motor ..... need magnetic shielding ! to be solved !
Started by titof, December 14, 2007, 02:19:16 PM
titof
Hi OU friends ! :)
I tried to replicate
http://jnaudin.free.fr/html/trmdiag.htm
not working for some reasons...  mechanic negative torque ...
I must tune  the magnet position...
But I wonder if Aluminium sheets Could be replaced by a better magnetic shielding ?
The problem is ... what kind of magnetic shielding?
It would be a better device to make without this problem ...
help !!! :-[
titof
hey guys ! :-[
I just want to know what you think about it
not to shearch for me -
Has someone maked this type of   device  working ?
many thanks !
;D
Freezer
tao
You want magnetic shielding?!?
<engage: slight sarcasm mixed with potential truth>
Why not use a superconductor, the PERFECT magnetic shield...
Oh, whats wrong, can't find yourself a ROOM TEMPERATURE superconductor?
Why not look in in sea salt, or water? 'What', you say???
An apparently 'UNTESTED FOR FREE ENERGY devices' room temperature superconductive element.... ORMEs...
Have a look-see: http://www.hbci.com/~wenonah/new/hudson.htm
"Researchers working with large magnetic fields discovered in the 1960's that metals when induced into a high spin state (using energies of approximately 540,000 gauss) were capable of passing energy from one high spin atom to the next with no net loss of energy! This was the discovery of superconductivity.
Superconductivity allows the conduction of energy through a resonance phenomenon. Unlike electrical conduction, energy can be passed from one superconductor to another with contact, without resistance and, therefore, with no net loss of energy.
To create superconductivity in a potential superconductor, an external magnetic field must be applied to get the system going. Once the flow of energy is set in motion, however, it is only necessary to keep the conditions correct so that the material remains superconductive. (Note: When it takes more energy to create a magnetic field to keep the atoms in the high spin low energy state than it would take to push electricity down a good conductor, the process is self defeating.)
Atoms could now be induced into a high spin state of low energy and be kept in that state without continuous applied energy boosts. The system currently in use, to induce atoms into a high spin state of low energy, is refrigeration combined with extremely high magnetic fields of approximately 540,000 gauss. The system now in use, to keep the atoms in the high spin state, is refrigeration to near absolute zero. All of this is an elaborate and expensive process."
"David Hudson discovered that the monoatomic state can exist naturally and remain in a stable state in the transitional group elements. (ORME) He also discovered that in this state, the atoms can join to become a many atom resonance coupled system of quantum oscillators, resonating in two dimensions, indeed perfect superconductors, at room temperature. (S-ORME)
Hudson discovered that the precious elements, in the group of transitional elements, could be found in a monoatomic form in certain ores and that by a chemical method, he could separate them out from these ores. The high spin low energy state is stable and naturally maintained. it needs no external manmade manipulation. The internal temperature of the atom is measured to be almost zero degrees Kelvin .(approximately three degrees). This is a naturally cold state. It is, in fact, a perfect superconductor. "
What the matter, never heard of ORMEs before? Heard of ORMEs but never saw how they were superconductive? Don't believe they are/can be room temperature superconductors???
Need some evidence???
Watch this attached video......................
More later, as always.......
;D
titof
wow!  great video !   my mind is now on !
wow!
wowowowowow!
i tried to let a magnet fall in a copper pipe !
amazing !
this will be a working device soon for me!    yahooooo!
muchas gracias !
merci beaucoup !
an infinity of thanks guys !
I will show results if it works !
;D :P
