nelson camus' reed motor ..... need magnetic shielding ! to be solved !
Started by titof, December 14, 2007, 02:19:16 PM
Freezer
Quote from: titof on December 18, 2007, 12:15:48 PM
it is also in the video ...
copper opposite a resistance when you shake a magnet in front ...
but why did he present this in the video ?
Maybe the blocker must have a special shape ...  triangle? ...
He's showing a little bit of the principle of his motor.  He first shows the rotating piece of metal which sticks when it comes within the field of the magnet.  Then he shows how to block the field.  So basically you have metal rotor being attracted, then when it comes close to the magnet, its field is blocked to not stick.  It would be a metal rotor so no drag would be created by the copper.  All this would have to be made with precision to work.  I think the way they use it, is as a flywheel pushing a generator, so theirs might not turn itself, but add more torque to turn a generator and gather more energy.  He says 5:1, but who knows.
vince
Hi Titof;
I made my own version of the nelson camus reed motor several years ago.  I used aluminum shielding as the original instructions called for but I had absolutely no luck getting it to spin more that a few revolutions. My motor was made out of aluminum  and steel as you can see in the photos and I had full adjustments to all parameters including spacing, angle,and position for both the magnets and the shielding.  I must have tried every different position available but could not get any results.  I had totally forgotten about it until I saw your posting.  Perhaps I will try different shielding material if you guys get any results with your efforts.
Good Luck
Vince
karl
Vince,
are there many armatures made of metal?
Too many?
I think we have to use metal only in the region where it should act.
A whole dielectric structure with only the blockers made of an electric conductive material.
Maybe also magnets out of an ceramic type material.
The right rpm should be the second factor to be resolved.
Only at a speed which induces the right ammount of local current to the structure, this was also a problem described by J.L.Naudin in that years.
Stay tuned
Anton
titof
happy to see your work vince ::)
Now we 've got the problem to find the right thick of blockers , the right surface size of it , and the right positon of blockers between each facing couple of magnet
see the video  on this post
we must reflect a little .
magnet + copper = no steel attract
can we insert any piece of steel in the device ?  maybe a right way ...
I think no other pieces of steel could be insert like screws ... no magnetic parasite  needed !
this device should logically work :
we must geniousely shield the magnets with other materials
nelson camus had succes ? was he lying ? I don't believe it
realize ! we have a simple device which can be a 50 $ or ? one ? every size is possible  ...
I dont speak about power and RPM ... It adjustable with blocker positionning !
we can tune an ac voltage as we need !
PLEASE ALL !
LET S REFLECT TOGETHER !
titof
I don't remember where I was reading this ..
but a type of magnetic shielding could be a mix of gypse and iron powder !!??!!
Maybe the copper blocker must have a special shape ...
ARE THERE ANY MATERIAL which eat magnetic field ?
to use the inverse polarity of this field could be a solution .. but hard to realize ...
maybe with electro-magnets ... It 's out of that we want !...
We want only a magnet-motor , no ? ...
I wonder ..
Is there a type of cristal which reacts with magnetic fields ...like piezo's ..
Maybe it's a better way to work on perendev-like motor
