"Self Running 900 Watt Fuelless Electrical Generator" Is this new?
Started by bourne, December 16, 2007, 11:07:06 AM
bourne
Hello gentleman,
I have had a thought after reading some of the other threads in this forum.
http://www.overunity.com/index.php/topic,4319.msg83984.html#msg83984
What if Turz is correct in addition to, here is my hunch; The 20 minute maximum running time of the TPU was NOT due to overheating but the run down of the battery. Mr Steven Mark could never get the device to power itself, that is why the only videos available are the 'first generation of idea pro-mos' to promote funding. In the end, the idea was given up on with it's final action being a slip in to obscurity. Until recently.
What we have with Mr Thrapp' s motor is the same principle but on a much larger scale, with it's clever variation. He was able to get it to self run and produce power enough to light 900watts (not confirmed) of incandescent bulbs.
Didn't he say he/they studied Tesla?
"Interestingly Wound Motor"
Patent #381,970
From the patent lines 53 onwards;
QuoteI use a core A, which is closed upon itself that is to say, of an aunular(sic) cylindrical or equivalent form and as the efficiency of the apparatus is largely increased by the subdivision of this core I make of thin strips, plates, or wires of soft iron electrically insulated as far as practicable.  Upon this core by any well known method, I wind, say, four coils B B B' B', which I use as primary coils, and for which I use long lengths of comparatively fine wire. Over these coils I then wind shorter coils of coarser wire, C C C' C', to constitute the induced or secondary coils. The construction of this or any equivalent form of converter may be carried further, as above pointed out, by inclosing these coils with iron as, for example, by winding over the coils a layer or layers of insulated iron wire.
"efficiency of the apparatus is largely increased"  ......  By how much?
"construction of this or any other equivalent form of converter may be carried further"  ......   hmmm
That could be a description of a TPU or what we see in the WITS video.
The WITS variation puts the generator inside the coils.
Magnetostriction  kicks keep it going when it is up to speed.
Does Magnetostriction travel at a certain speed?
From the patent line 23;
Quotethat as the generator coils revolve points of greatest magnetic intensity in the converter will be progressively shifted or whirled around
Would that set up a pumping/bouncing motion in the Ether contained in the iron/copper converter ? The energy removed from the system via the coils would simply bounce back out of the Ether.
Remember, I started with a presumption with a hunch tacked on!
Please don't tear me apart if this is nonsense. But that patent keeps showing up:)
381,970
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
nightlife
Erfinder, "The dual natured vibration which nature repeats ad infinium in all of her doings is centered by stillness. A  polarized mass of metal is a testament to this truth."
Now I think I know what you are talking about. It would be like the stillness between a north and south pole of a magnet. Or a centered pressure point between two forces.
I was thinking you were referring to the start of time. Sorry.
How would we go about tuning in the center between two frequency's? This seems to me like it would be impossible to do since the center would have no vibration to be able to tune in. How do we tune in a signal if the signal doesn?t have a vibration? How can a signal be a signal with out having a vibration?
You were right, I cant comprehend what you are saying. It is beyond what my level of common sense can relate to. Sorry to frustrate you with my ignorance and I will now leave this alone unless by some chance I just happen wake up and see this in a different way then I do right now.
esaruoho
Quote from: hansvonlieven on December 16, 2007, 02:51:55 PM
G'day all,
I wonder how many suckers they get to put money into their scam.
Hans von Lieven
hello Hans.
you, as a john keely interested -person, i'd say you'd have something of consequence to say to this video of theirs:
http://www.youtube.com/watch?v=06iCfowinUM
can't wait to hear your analysis on this one :)
esaruoho
Quote from: hartiberlin on March 13, 2008, 07:35:55 PM
Hi All, I got an email from John and we are discussing now first privately, if and how an interview can be done and under what conditions.  If the outcome is positive, I will let you all know.  Many thanks for your patience. Regards, Stefan.
what was the end result, please?
ramset
ESA you stated a few days ago that Mr Thrapp had sent you a contact number  for the purpose of assisting a new video release  Hows that going ? seems like the hottest leade to date !! Chet
Thanks Grandma
