"Self Running 900 Watt Fuelless Electrical Generator" Is this new?
Started by bourne, December 16, 2007, 11:07:06 AM
0 Members and 18 Guests are viewing this topic.
Groundloop
@Earl,
It is not a deduction of Timothy's motor / generator. It is a further development of my
iron center rotor setup. But I thought it looked a bit like the Timothy's system so I
posted it here.
My motor circuit is designed to trigger on North passing magnets. Only two coils opposite to each other will be firing at the same time. I have tested that the the outher generator coil
works in this setup.
>Do you see any possible source of FE for this configuration?
Maybe.
Groundloop.
gyulasun
Quote from: Groundloop on March 06, 2008, 01:53:11 PM
@EMdevices,
The biggest problem is to find the Henry value of my coils since I do not have a meter for measuring inductance.
To find the RPM is easy, just hook up the scope to the motor coil and measure the pulse repetition time.
Then I use f = 1/t. Knowing that my circuit will only fire on the North magnets passing I then
divide that value in two and then divide by 60. This gives me the RPM.
Groundloop.
Hi Groundloop,
Although EM suggested a good inductance measurement method, here is another one if you like:
http://www.coilgun.info/theory/measureinductance.htm
You could use a normal linear potmeter instead of the resistance decade box and in Step 5 you could measure the potmeter setting with an Ohm meter of course.  If you have coils with high copper resistance that would happen to approach the series potmeter adjusted resistance, then you have to measure separately the coil DC resistance and consider it in the measured potmeter resistance for a more precise calculation for your coil's L.
Also, if you have coils with lower number of turns (i.e.  L values of some milliHenries only) you would prefer using only 2-3V AC voltage for the measurement at your 50Hz to limit the current in the measuring circuit (potmeters do not like the higher milliamper currents that tend to flow in cases of low inductive coil reactances...).  Or if you happen to have a low frequency audio generator-like source, it would also be great instead of the mains transformer.
rgds,  Gyula
PS: See this link also for a similar method, although it needs a 1V AC audio generator source (or a 1V mains transformer secondary output) : http://et.nmsu.edu/~etti/fall96/electronics/induct/induct.html
EMdevices
Quote...I have a feeling that the key to all these systems is the timing/switching and the proper use of resonant coupling.
Hi Feynmen,  what you mention is probably the key, the right timing/phasing and resonance.
@ all,
you know what I've been thinking,  this might be a breakthrough in the TPU mystery !!!
Where's what has become apparent to me from the Thrapp motor, and I'm so glad I saw this thread.
We need electromagnetic resonance of the tank circuit formed by the generator windings and an external capacitor, but we've seen that we need fast rotation speeds or we'll need lots of inductance and capacitance.
However,  what if we replace the mechanical rotor with the stator of an AC motor that creates ROTATIONAL MAGNETIC FIELDS ?
So, replace the rotor in the generator, with a STATIONARY armature that can produce rotational mag fields with phasing, like in AC motors.   Now speed is not a problem, no mechanical limitations !!!!!    Didn't SM mention something about the need for HIGH SPEED?   Now we have two stationary motor/generator circular coils in close proximity, one playing the motor function, the other the generator (and loaded with capacitors for resonance).  This now begins to look more like the TPUs!!!
Is that wild or what?,  Now we don't have mechanical limitations, and can get fast speeds and we can do it with small capacitors instead of a box full.
So to recap,
1)  CREATE ROTATIONAL MAGFIELDS WITH 2 OR 3 STATIONARY PHASE WINDINGS
2)  IMPLEMENT THE GENERATOR WITH CAPACITORS CONNECTED TO THE WINDINGS FOR RESONANCE
3)  EXTRACT ENERGY !!!!!
EM
P.S.  At any rate,  I wondering if the extra energy comes about due to ROTATIONAL aspects coupled with resonance, or if this can be done with linear systems?  I guess it's premature to speculate.  I want to duplicate the Thrapp motor setup first, and then try and simplify.   I'm getting excited again, just like with the Mike HMM, Bedini replicated motor, the famous SELF RUNNER  :)
ramset
Thanks Grandma
EMdevices
And to illustrate with a drawing,  here's a simple device:
1) Ring with 4 coils for creating rotational mag fields
2) Center ferrite inductor and capacitor as the resonant tank to be excited to resonance.
3) Extra windings for extracting high current output.
EM
P.S.  If this doesn't work, then maybe we need another ring with 4 more coils for the generator function (just like the Thrapp generator) and then hook that up to the capacitors.  If that doesn't work either, then maybe the mystery is in the magnets and we need physical motion, or maybe I'm full of it and speculating in the wind  :)
Remember, the input power (the two phases) should also be high frequency, NOT your 60 Hz or 50 Hz grid power.   This is the whole point, to bypass the mechanical limitations of a motor and go for that high speed, however, it might be easier for people to experiment with motors since creating a 2phase circuit might be a bit beyond the skill level of most folks.  I haven't built one either, so I'll have to research a bit.
