Thanks to ALL for your help!!
I have a working shuman resonance circuit for sale
Started by magnetman777, December 16, 2007, 04:13:21 PM
magnetman777
Dear Gentlemen,
I have some good news. I have been able to create the same vibration in my coil as SM. I know how to do it. And why it vibrates. I also know why he puts a magnet on to the TPU to start it.
I have also made a circuit that can receive the Shumen resonance frequency at 7.3 Hz. I will sell the plan for the circuit for $ 25 a copy with a schematic and a parts list. I would appreciate that no one post this circuit .The circuit is easy to build and takes 1 night depending on your skill level. This circuit will hear all RF resonances from about 40 Hz down to 2 Hz. The output of this circuit can be driven into a audio amplifier or just observed on a scope. If you use a scope that has an X Y in put you can inject 7.3 Hz into X and let the circuit inject Y you can see the circle pattern when your generator is at the same frequency that the receiver is receiving on. I will be posting the circuit on eBay later this week. Or you can PM me direct for the circuit.
I have also figured out or have a good theory why SM is saying to use tubes. This pointing is not literal it is a clue. The clue is high voltage. Tubes work with high voltages. High voltage fields is what is necessary for the TPU to work. SM uses the word resonance  to describe his theory?s . Being an RF guy I use that term a lot. Look up what is called a class C Rf amplifier this will explain why SM TPU has a high freq arc and DC on his output. Any coil that is pulsed near its resonant frequent will produce the highest field it can. If you measure the DC input of the class C amplifier when it is tuned to resonance it has its highest output and it draw the least amount of current. That is what makes it an efficient amplifier for a narrow band amplification. If you rectify the out put of and RF amplifier you will get the exact same effect as SM s output spark. What SM did was to make a 5000 Hz class C Rf amplifier then he rectified the output.. I don?t think SM had and over unity device just an efficient dc to dc inverter utilizing RF principals.  Remember no one has ever seen his device work for more than an hour. Because his batteries would go dead. Lets face it there are a lot of very smart people in here trying to get this device to work with no luck.
So either SM is a fraud or we are all being mislead.
I believe that that the keys to this over unity situation is in resonance, magnets and hi voltage.
More later
Magnetman777
starcruiser
So Magnetman777,
Your theory is what I was thinking, My idea was to use a circuit similar to what Dr Stiffler is using but use a small torrid instead for the oscillator (blocking oscillator) and use a single wire or small coil for the antenna from the oscillator and use one or two tuned receiver coils (cut to 1/4 wave length of the osc freq) for the output or collectors. I was figuring on a AV plug for rectification. all coils would use a single lead (single lead connection for the input and a single lead for the output. The output coil would use a stranded wire to increase output.
Am I close to your design or theory?
Regards,
Carl
starcruiser
Oh I forgot to mention the use of the magnet is to provide the field to couple the coils and the earth field. I think I may be close to your design. I will be playing with my idea over xmas break (taking a week or so off from work and will have the time to test)
Regards,
Carl
Bruce_TPU
chrisC
Quote from: magnetman777 on December 16, 2007, 04:13:21 PM
Dear Gentlemen,
More later
Magnetman777
Magnetman777:
Congratulations! I like to believe you haver solved this diffilcilt problem with some intuitive efforts. I love to send you $25 to reward you for your efforts. However, how about first posting a short video to show us without ambuiguity the circuit actually works? Surely that's not too difficult? I hope you can do that for the good of all. Thanks
chrisC
