fact ! we are all here to find a F E device and make it runing ! so... :
Started by titof, December 17, 2007, 03:20:27 PM
Mem
<<Bill, yes a lots of people are working with the similar devices. This back emf thing, that I am working with.
The one that I am working with, I feel is quite simple device since all the parts are off the shelf materials.
and yet has the ability demonstrate ou.
Device simply works with pulse DC. you pulse the power into a giant transformer (my transformer is 98 lbs) and collect the collopse back electro magnetic field, thats all there is to it.
The way I see this circuit that works is like this:
Imagine large pendulum your start pushsing this thing back and forth, after while you only need small amount energy to keep the pendulum going, right. Then once you get this thing going each time that pendulum will swing back to you will also do free work for you. That swing back energy is far greater then input energy.
But, back EMF is far better then pendulum because electricty has no pysical weight therefore can start and stop vvery quickly. Since there is no armautre or anything like that, start and stop causes no problem at all.
As of this evening, the circuit is able to clearly shows eccess output energy.
1-At the out of the circuit 15 Watt AC (wire resistor) bulb that brightly glows. (Normaly this bulb won't glow with 12 V battery.
2-Or I use this motor as a load (see it herehttp://www.surpluscenter.com/item.asp?UID=2007121801551907&item=10-2190&catname=) normaly this motor runs with 12 V battery very slowly. But when I turn the circuit on motor slowly starts to eccelerate to very high speed.
I bured up, many 12 volt (automobile) bulbs. With the flash they go, I am not going to use them any more.
If I video tape this, will be very impressive.
Mem>>
titof
@ bill
"@ titof:
    I think what you are proposing is already going on, to some extent.  What I mean is that I feel that     a lot of the different topics here are more related than we know right now.  Dr. Stiffler, earthbatteries, back emf, micro tpu, etc.  I think we are all playing with the same thing in a slightly different manner.  I think Stefan did a service to the world by creating and maintaining this site.
Bill"
Yes !  It's true but my think was " take the experience of all and focalize it in a project we would choose together for a simple device"
Maybe this post is a sword hit in the water .... :P
Koen1
Quote from: Mem on December 17, 2007, 04:16:49 PM
<<Hi Titof
I know exactly what you are talking about... I too been doing R&D more then 20 yrs. I have seen a lots of video's of ou devices online "like everyone else" so for after all this time of reseach I was able to creat this siple circuit that is ou with out a doubt or a question.
I offered to public as a gift. In the hope that people will use it and even someone will develope it further then I have done.
See the video here http://www.youtube.com/watch?v=LlOP2LD-IpI
and Exact circuit here http://backemf.onewithall.net/html/mehmet_circuit.html
When I posted this news here about 6 months go few questioned me "like FBI agents" and debunked the device all together.
But I know that this circuit is true and and working. If you have access to welding transformer try it, if you will.
You'll be amazed how much access back emf energy in return you'll get.
If you try this circuit and use charged battery, limit the input amps to the circuit by using wire resistor
or use discharged car battery to power the circuit.
This circuit needs to be more refined to be able to turn into a product. But as is do in deed demostrates ou.
Mem>>
Hey Mehmet, nice vids and thanks for posting this circuit and your experiments! :)
It does indeed appear to have some similarities to the Stiffler-, Newman, and Bedini circuits.
But where the Newman and Bedini designs pulse a motor to generate the back emf, you're using trafo collapse...
And looking at your video of the lamp it seems you are indeed doing so quite effectively.
Very interesting!
I hope you will continue to share your findings on this forum?
Thanks for sharing, and good luck with your experiments!
titof
MEM !
very interesting !
it is like "FUELLESSPOWER.com motor" except they pulse 200 to 1000 volts to run a magnetic motor through a tesla flat coil !  interesting too
your device is cousin with MEG ... isn't it ? :)
Koen1
Doesn't look like a cousin to the MEG at all...
The MEG uses pulses to guide the magnetic 'flux' from a permanent magnet along the 'right' and 'left' side of a magnetic core alternately,
thereby inducing a transformer-like pickup of the pm flux in the secondaries.
This appears to pulse a normal transformer, without 'intercepting' the flux from a permanent magnet at all.
In fact, seems like a less complicated setup to build than the MEG.
Doesn't even use a permanent magnet at any point.
Big difference. MEG's OU output supposedly comes straight from the permanent magnet. In Mehmets circuit it seems to come from the
collapse of the magnetic field in the transformer... Which makes for the interesting question of where the excess energy comes from.
Is it part of the Heaviside component that gets absorbed when the trafos field collapses?
Not that I mind much, as long as it works ;)
