Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
BEP
@ronotte
Your theory is plausible. If Miller capacitance is doing this then you may have a MOSFET Negative-gm differential VCO. It is possible to build a very simple polyphase oscillator doing this.
This could explain why I'm not seeing the same thing. My opto-coupler is part of my FET assembly inside the coil.
If true then this is still a great realization - good way to know the true resonance points and tune without generators.
hmmm.... a polyphase blocking negative-gm voltage controlled oscillator? PBNgmVCO ! - There. I've coined the name!  ;D
Seriously - this would be the simplicity needed and the same effect can be done with tubes/valves.
otto
Roberto,
no doubt that I want to try it.
As I remember, your collectors have the same nuber of turns??
Again, please, measure the picofarads in your TPU!
Otto
M@rcel
Not sure if this is off-topic, if so sorry  ;)
Where does G-strain fit in? Look here: http://jnaudin.free.fr/html/gseamnu.htm
when you scroll down you'll see this picture:
Looks slightly familiair
ronotte
@Otto, BEP,
I do join with your thinking as , if again confirmed, it does means that we CAN GET RID of all the electronics stuff as it's simplicity is really stunning.
Otto, I can make any measure you want: this evening I'll start, but firstly I'll check again the 'sustained operation' and doing it while increasing the voltage applied till +45V...I can't wait to see what will happen.
Roberto
Gustav22
Hi Roberto,
Quote from: otto on January 14, 2008, 07:51:45 AM
I also wanted to ask you the same question.
As otto's collector setup is like this:
Quote from: otto on January 06, 2008, 03:13:58 AM
top collector - 9 turns - lamp wire
middle collector - 5 turns - lamp wire
bottom collector - 3 turns - lamp wire
How many collector-loops do you have in each of the 3 stacks?
money for rope
