Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
BEP
Quote from: ronotte on February 07, 2008, 07:38:43 AM
- Is there a rationale in putting the lamp inside the TPU?
Yes, I sent an explanation via other channels.
Such ideas are fodder for the lurkers and knuckle-whackers  ;D
I'll let you come to your own conclusions.
If there is no noticeable compass rotation the I should ask - Is there a compass deviation from the norm while in the center? Like pointing the wrong way or not wanting to find North at all or the needle not being level.
Bep
hartiberlin
Hi Roberto,
great videos and great hard work done !
Congratulations.
But what do you mean "this is 30 Volts and this is 50 Volts" in your last youtube video  ?
Is this the power supply voltage ?
How many amps are you drawing from your power supply during the light bulb is lighting up so bright ?
Many thanks. Regards, Stefan.
Bruce_TPU
Quote from: ronotte on February 07, 2008, 09:48:57 AM
@Bruce,
do you think I did not know?........If you just have a look to my previous post you will see that I already DID it.....so no way to warn me again....nevertheless I thought interesting for all to see it  (..not LEDs shininig..He He...).
Roberto
Hi Roberto,
I found your reference, and understand.  No OU yet.  You are getting close and I greatly admire your work.
Warm regards,
Bruce
HopeForHumanity
I think he means by the messing around with it, it can range from nothing to overunity... i'm confused too.. :-\
EDIT: I get it, he can set power consumption to zero, yet the brightness stays the same. Thus find the correct frequencies then shut it off...
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
BEP
