Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
EMdevices
Rosphere,Ã,   well said.
I can relate to this frustration quite well.Ã,  I feel the same.Ã,  However, let me assure you that nobody has a TPU !!
Some of us THINK we have TPUs but we realy don't.Ã,   Why?Ã,  Because we don't know what a TPU is, there is no absolute specification for it.Ã,  Perhaps we need to define first.
What is a TPU anyway?Ã,
We are talking about the Steven Mark's toroidal power unit, but we don't realy know the principles that it works on with utmost certainty,Ã,  but we do have a good idea about some aspects of it from what Mr Mannix has told us.Ã,  Supposedly this information came from Steven himself.Ã,  Then there are the videos, and from some of the videos you get the feeling that it's not using any types of batteries.Ã,
I don't want anybody to get upset, because some people here are doing great work and are exploring and experimenting, which is all we can do, but we can't realy say we have a TPU like Stevens if we input power into it.
When we make a TPU that exibits power loss when turned upside down, and it has no batteries, and it can light two 100W bulbs and, has some vibration to it, and it's activated with magnets, then maybe we can say we're close to what Steven has, then maybe we have a TPU !Ã,
But untill then it's just experimentation.Ã,  Steven just provided for us inspiration in what area to look, That's all.Ã,  He realy couldn't tell us due to the politics involved.
As a side note:
I don't want to discourage the folks experimenting with tubes, but frankly, that's not where its at and it can discourage folks.Ã,  You can learn alot from it, but if you want oscillators you can get them impremented in silicon with high frequency transistors.Ã,  Steven was just telling us his roadmap and how he discovered the effects, and in his time tubes were used alot.Ã,  Does this mean we have to travel the same road?Ã,  Maybe maybe not, but we can build oscillators easily now without tubes.Ã,  My mini-Tesla coil uses about 10 Volts and low voltage transistors and yet it can output over 1 kiloVolt and cause arcing.Ã,  What we need is solid accurate knowledge of how to design proper circuits with what's available nowadays.
EM
EMdevices
Chef, I don't use TUBES and I consider myself a TPU researcher.
If you feel like using tubes, go for it, all I'm saying is , it's not necessary.Ã,
With tubes, we are getting farther and farther away from running without batteries.Ã,  We are now dealing with high supply voltages, transformers, AC power, etc,..Ã,  and that's not what a TPU uses.
EM
c0mster
giantkiller
Wow.
The fustration comes in waves across us equally. Especially when the waves of individuals heterodyne into a standing wave. ;)
We are not standing still. This a is a mandatory break in thinking. It happens in productive thinking circles.
I am still impressed with the calibar of minds here. There is non like it in the world and don't a little fustration stop this. Somebody or a collected team is on the verge of the next step. We all know copper and frequencies. 'nuff said. It is the combinations we are stiving for. Since the first group back 1 1/2 year ago came on board they have added and dropped members. No one works alone as long as they share. We have all done that and that is commendable.
I have slowed down or it appears to be. I too have been watching results and felt it was time to take stab at a leap of faith in putting more stages together. I have seen all these proven by you all, Tesla, Schauberger, Keely and the likes.
You can't run around dragging your wings on the ground and call it flying. Any way that is my quote of the day. I have more to do.
The setup I am working on will drive the coils to get the magetic fields pressured into the center. Then impose an ac signal on top of that and moving in a counterclockwise direction to get the heterodyning effect in that center. (Schauberger, Keely)
The diameter of SMs smaller coils facilitated the smaller dc bias. The field didn't have to go that far to touch another field. You, yourself can touch the edges. Don't touch the center.
1 1/2 years I had posted a TPU in parallel with the surface of the Earth. Marco immediately reposted the pic with the vortex top and bottom in it. I trust in what he says. I think I know where I am headed with this effort.
If you need high voltage then get a stungun. 8)
--giantkiller. Life is what happens when we are making other plans. :'(
Mannix
Hi guys,
not wanting to discourage any body but high speed electron flow has been pointed out as essential
the speed of semis has been pointed out as a limiting factor.
Experimenting with tubes is easier especially at first.
The best of luck for any body ,whatever you use to experiment, but high voltage seems pretty common.
Another thing to think about is that what you see in the videos are running units......that are activated........is it possible that the process was  started by something else. its like a car that develops 500 hp...yet it is started with some lead and some acid.   we dont admire  the battery do we?
Just try keep an open mind ...the enormity of this discovery excludes most common ground so we really need to use what little we have...as well as we can. Luck will play a part as well
good hunting whatever your chosen tools
page 1 of master of magnetics ...
Lindsay Mannix
