Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
nickc44
Lindsay,
Good to see your keeping up with the guys have you been building also...
the guys have been doing a great job and have been keeping us all interested
I have been working with another project Bedini with my own twist
it has its moments Once I finish what I'm doing I hope to start building the TPU
Just looking to see how your doing
Nick
Gustav22
Quote from: wattsup on February 12, 2008, 08:26:40 AM
@Gustav22
From your post, do I understand that you have built an ECD with the three CCs, or are you building the TPU 10 type unit?
I made a 3stack as depicted here:
http://www.overunity.com/index.php/topic,3660.msg62585.html#msg62585
(not an ECD).
This was how it looked at some point during building:
Click on pic to enlarge.
It is the same basic layout which ronotte used for his TPU V10
However, testing will have to wait until the end of February.
@ronotte
You have explained this to me before, but I did not understand properly, so I want to make sure:
The output signal of your unit with 5" collector diameter (6" diameter of total unit) is visible in your scope shot posted here:
http://www.overunity.com/index.php/topic,3779.msg75454.html#msg75454
In this unit you use 3  frequencies as input on the CCs (15 kHz, 30 kHz, 105 kHz).
Now the question:
Does the output 3sister-signal (for lack of a better word) have the same frequency as the highest of the 3 input signals?
In other words: is 105 kHz also the frequency of the 3sister-signal in your unit?
edit:
I realize that the question is not stated properly, as the 3sister-signal is probably the same, even if a chord not containing 105 kHz is used for excitation.
So maybe the question should be phrased like this:
Is the frequency of the 3sister-signal always equal to fundamental_excitation_frequency * 7 ?
f3s = 7 * ff
frequency_of_3sister = 7 * fundamental_frequency
money for rope
otto
Hello all,
@wattsup
thanks for your kind offer. I will try to find this caps in my city, somehow. But maybe ....
@giantkiller
you mentioned a stungun. What about a flash unit from a camera? Or just coils primary - secondary, the primary, one end connected to the secondary like in a car ignition coil, to get a high voltage? Like in the ECD?? Easy to make!
@All
I want to use tubes because in the past I blowed so many various MOSFETs that Im not able anymore to buy them and I dont want them, until I see my "TPU" working with tubes and THEN I can think about how to get rid of the oscillators and the power supply.
A nice long journy is waiting for me.
To be the first? Glory?
NO THANKS!!! Everything that I know is already posted.
I just want it, nothing more! But I have to deserve it with my work!
Sorry to wright this but that are my feelings about my 2 years work. Maybe I have to spent another 2 years for a TPU?? Fine with me. I have time.
Frustration?
NO WAY.
Im surching for a solution and if I fail I have to turn my mind in another direction and try again and again and....
At least I know about hundreds of ways how a TPU cant work, ha,ha.
Otto
ronotte
@All,
thanks to all for showing your ideas because that's just a way to 'feel' that we are not alone. In fact many of you guys even if  not posting are without any doubt active and following what it's happening here.
My personal opinion, for what it worths, is that we all are living great times and for sure now or later we will get remunered: so let's think positive.
I AM NOT FRUSTRATED!
On the contrary 'I never have been so happy like now'. Am I a dreamer? I don't think so as what I've seen (and I'm not joking and/or auto-convincing myself) in this period is  so evident that I'm FORCED to proceed on this already pawed way.
So Rosphere & other: I do appreciate a lot what you are sharing (...there will be soon time for your Rodin to be put in action..), the problem is that the scenario is continuosly changing so unless to discuss it day-by-day is almost impossible to contribute. Of one thing you may be sure: I WILL SHARE WITHOUT HIDING ANYTHING MY WORK'S RESULT.
Roberto
giantkiller
@Roberto,
I know you are not fustrated. You press on diligently without fault. And like a great engineer you are meticulous about the documentation. Hats off to you! This whole process is a Godsend to those who want to jump in and are apprehensive. They will pick their spot to get onboard. We, so far, have done this. And isn't it great!
The 3 channel FET driver configuration I made to drive the ECD is now brought forward to hook the BFG2k8 to . This is a 3 layer, 3 segment ECD. Thank you for that.
Pump it up!
About the stun gun or flash? Tesla says High speed current. The effect can be seen the whitish, bluish purple flashes. The SM17 does this too the larger the load / smaller resistance / short. 8) It just keeps pumping a charge out. 8)
--giantkiller.
