Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
nickc44
Hi All
This is a test Post I'm having problems with my PC
nickc44
Otto
I will try this again it looks like the file size is too big
You had said check out the drawing that shows the hight sizing
it shows the hight at 44mm
The question is he raps it different than you ( or is it )
he raped the bottom ring first then bottom and middle and then bottom middle and top
I'm raping my TPU soon and would like the clarification
Thanks
Nick
nickc44
@ Otto
I hope this comes through. This is your Drawing and I'm just looking to see if it is still a current
wire Diagram I know you have changed the number of turns so I'm looking at just the drawing
and its connections and configuration.
Thanks
Nick
http://www.overunity.com/index.php/topic,3779.msg68404.html#msg68404
otto
Hello all,
@Nick
Im using 9 turns for every collector coil. Lamp wire.
My controls are 57 turns for each control coil, for now. Maybe later we need more but in this moment I dont know it exactly.
The picture you showed us is the side view of my TPU. As you see my bottom controls are wound around the bottom collector but the middle controls are wound around the bottom AND middle collectors....like the 3 stack.
Otto
nickc44
@ Otto
Thanks for your responce
So as I see it ( In my pea brain  ;D ) I'm seeing two possible configs and only one is Right so these are
the 2 Types I see..
Type A
Collector Coil 9 Turns Lampwire ( We have 3 of these Top Middle Bottom )
Top Collector Coil will be rapped with Control Coil 57 Turns 24 AWG
Middle Collector Coil will be rapped with Control Coil 57 Turns 24 AWG
Bottom Collector Coil will be rapped with Control Coil 57 Turns 24 AWG
Rapping  all of these with a 2 Feedback/ 100 watt bulb cables of 256 Turns ( 24 AWG or 28 AWG )
This Is not like your side view drawing but is it Correct ?
Type B ( This is what I see in your side view Drawing )
Collector Coil 9 Turns Lampwire ( 3 Coils )
Bottom and Middle Collector Coil will be rapped with Control Coil 57 Turns 24 AWG
Top Middle and Bottom  Collector Coil will be rapped with Control Coil 57 Turns 24 AWG
Then Rapping  all of these with a 2 Feedback/ 100 Watt Bulb  cables of 256 Turns ( 24 AWG or 28 AWG )
This Is more like your Drawing ( To me )  but is it Correct ?
1  Tell me if Type A or B is the way to rap my TPU and then any corrections to the one you choose.
2  Should the Feedback be 24 AWG or 28 AWG ( I need to order cable )
Thanks again
Nick
Quote from: otto on March 10, 2008, 02:09:13 AM
Hello all,
@Nick
I'm using 9 turns for every collector coil. Lamp wire.
Otto
