Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
Earl
double post deleted, see above.
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
I almost forgot....
I also have it on good source that Litz wire is braided to cancel the magnetic fields.  That might help out the cannon ball effect, as induction onto the collectors zips them along, faster and faster!   ;D
Litz is a TPU builders best friend.  ;)
Merry Christmas,
Bruce
Super God
Quote from: btentzer on December 21, 2007, 10:02:35 AM
Quote from: otto on December 21, 2007, 01:22:51 AM
Hello all,
@btentzer
let us first clear up the therm "litz wire". Yes, we discussed it a long time ago. Lets do it again and then I will say something about it.
Otto
@ Otto
Earl said it well, both in English and German!  LOL
Each strand is teflon insulated.  So you can end up with 1000 wires, just like SM said.  This wire ONLY for the collector.  It is very expensive wire.
@ All
Reread what I posted on what SM said about this.  Litz wire is the only thing that fits.  Lamp chord will make no difference, because each strand is not individually insulated.  It was SM speak for Litz wire without coming out and saying Litz wire.  And then he gave us that story on top of it.  Insulate each strand and use that only for the collector and now you have understood what SM said.
I would go so far as to say (and I am not the only one who thinks this) that if this wire had already been used for many experiments, much better results would have been seen.
I will post again the pertinent part of SM's post.  It is so simple, I do not understand why I did not really understand the principle he is relaying, earlier.
"Let me give you something to think about...
If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short.
OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power available.
If we put it into a perspective of power per inch it may be easier to understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch.
If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire. (This is what we have all been doing, one wire, but with magnetic fields!)
Understand that I am trying to convey a principal that you can understand for use in the future.  (That future is now!)
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it.
If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say. (This is EXACTLY what Litz wire does for us!  Without this main ingredient, we will never see OU with this device, IMHO.)
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc.
If you connect the wires in parallel you will get higher current but lower voltage.
However, the power potential is the same whether you run the wires in series or parallel.  (This part tells us EXACTLY how to either increase amperage, or have high voltage, depending on what we want for the output of the three collectors.  I would strongly suggest building the Stack TPU but use 1000 pieces of wire for the total amount of the collectors.  Litz wire.)
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.  (The circuit potential is probably close to the stack tpu drawing, if not it exactly.  Frequency could possibly be the one that is the resonant frequency of our 1000 pieces of wire, which is SM's short pieces of wire comment here.  I would further state, that I do not think that the control wires ever connect to the collectors.  Call it a hunch.  Induction.)
you would be fascinated with the amount of renewable energy you can extract from a permanent magnet!" (If you want to test this, run a magnet over 1 piece of wire and measure the output.  Now run it over 1000 pieces.  Which has the greater output??   ;)  My guess is that SM played with permanent magnets and litz wire, quite a bit in his early days, and saw this very simplistic principle.)
EDIT:
Litz Wire
MWS Wire Industries
31200 Cedar Valley Drive
Westlake Village, CA 91362
Phone: 818-991-8553
82.02 USD per pound, with a 2 pound minimum
55.86 USD per pound, with 10 pounds.
29 linear feet per pound
105 strands of copper, each is poly nylon coated.  Each strand is 30 awg.  Total wire (all strands) is 10 awg.
Quote #93921 When asking for it.
Bruce
It makes perfect sense!  Earlier this year I had no idea what Litz wire was, I thought it was just some funky lamp cord wire or something, but the fact that it's INSULATED from each strand is new.  I can't wait to get my hands on some.
>9000
acerzw
Apologies can someone post a link to the three stack diagram... many thanks,,, catching up...
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Ariochdm
@ Otto
You asked why your test unit lost weight.  You might find the answer in the information related to torsion waves.  A good starting point for understanding them can be found at http://www.divinecosmos.com/index.php?option=com_content&task=view&id=95&Itemid=36  The Russians have been doing a lot of work on the aether and some of information from their experiments has been coming to the surface in recent years.
