HERE IS YOUR FREE ENERGY. HANDLE WITH CARE.
Started by 0ne, December 19, 2007, 06:23:49 PM
the_big_m_in_ok
Quoted from: WilbyInebriated:
"hieronymous richter? or thomas hieronymous? im assuming thomas due to context, but i wanted to make sure."
>>Probably Thomas.  He (I believe) went by the name, T. Galen Heironymous.  The one who invented plant and animal diagnostics, which amount to Radionics, per se.
Now that I think of it, Heironymous' works, assuming it's about equal to Radionics, isn't exactly free energy as such, unless it's on a higher level of energy somehow, as some might maintain.  Not quite the type of subject for this forum unless the Moderators decide to greate a Forum for the subject?
That would be fine by me, but my interest is in free energy and high voltage electronics.
--Lee
Cap-Z-ro
Big_m quote:
" Not to dampen your spirit, however.  If you get the inspiration, then follow your hunch, by all available means. "
Not to worry 'M'...if you knew my background you would know that absolutely nothing could ever dampen my spirit.
There's nothing like trial by fire to steel the resolve.
I am going to try some dream techniques soon though...here's hoping I can reach someone with the knowledge I need.
Regards...
forest
You should investigate one very important issue.Every inventor I checked has first built small toy-size device operating in a few watts range or even not so high.Floyd Sweet,Moray,Henderson,Hubbard, Steven Mark - check articles,videos.They HAD a small device first. Cyrstal radio is such very very small device. THEY HAVE LEARNED how to SCALE IT UP !
The key is resonance and the key to resonance is positive feedback.You must know where is "the potential of device", how it can be reused, and "not kill dipole" as Tom Bearden is saying all the time.
For crystal radio is would for example mean : use receiver to generate signal sent to receiver which interference with original signal , with harmonic resonance for example to reinforce it. Then find a negative regulator to prevent runaway situation.
the_big_m_in_ok
"Not to worry 'M'...if you knew my background you would know that absolutely nothing could ever dampen my spirit.
Regards..."
@Cap-Z-o
That's the spirit!  Whatever works for you.  Good luck!
--Lee
the_big_m_in_ok
the_big_m_in_ok
Quoted from forrest link:
"You should investigate one very important issue.Every inventor I checked has first built small toy-size device operating in a few watts range or even not so high.THEY HAVE LEARNED how to SCALE IT UP !"
>>Very good!  I agree 100%.  The Boeing SST fell from ambitious politics and greed to some extent.  It was overbuilt and failed.
"The key is resonance and the key to resonance is positive feedback.You must know where is "the potential of device", how it can be reused, and "not kill dipole" as Tom Bearden is saying all the time."
>>Sorry, I'm not familiar with Bearden's work.  I might check into it, though.
"For crystal radio is would for example mean : use receiver to generate signal sent to receiver which interference with original signal , with harmonic resonance for example to reinforce it. Then find a negative regulator to prevent runaway situation."
>>Good.  I think I grasp what you're trying to say.  Radio receivers are tuned to discrimminate the transmitted signal out of the entire spectrum of radiant energy and amplify that so as to be understood as an intelligent message, right?
--Lee
