Negative Pulse Application [Cold pulse]
Started by libra_spirit, December 25, 2007, 05:35:46 AM
libra_spirit
Quote from: ronotte on January 02, 2008, 02:27:03 PM
Hi Dave, EM,
in my 2magclashTPU experiment, placing a very strong NEO near the Control Coils has been one of first tests I did.
Conclusion: NO WAY TO CHANGE THE 5MHz 5 CYCLES sinusoidal train following the switched waveform trailing edge
Just to be sure If remember well I tried also to put a tank capacitor in order to see if any way to tamper the 5MHz:  NO WAY.
The 5MHz oscillation was ROCK-STABLE insensible to any effort to change it! I took it as NMR.
So I used it to take out power as the oscillations were so strong (> 150V ptp if I remember well): all is well documented and to your disposition.
I did said test following Dave suggestion as reported in his published document. Anyway I must say that inspite of any effort I've not been able to obtain any OU as Dave suggested!
Roberto
Good info Roberto thanks for relaying that experiment.
I have still been reworking the document and adding changes to my basic though progression as the interactions become clearer.
Another very compelling though has come up, that of extracting current, from a voltage source by tapping certain parts of the waves cycle.
I added near the end my thinking.
Thanks all for the responses.
On the magnet experiments I came up with very similiar results and Marks info was correct and much appreciated. However there is a link in AC to the mass rotation, but not exactly what I had formulated earlier. We shall see what transpires!
Dave L
libra_spirit
Otto showed that specific lengths of wire interact differently to the initial spike of the square wave.
There are other examples of wires cut to specific lengths where some kind of nuclear torsion rises strongly out of the wires.
We discovered these lengths on the scalar coils using absolutly no EM.
http://magnetism.fateback.com/EarthGrid.htm
Lyle Lathem had developed a particular coil length that seems to strongly light up with torsion and we were studying it looking for connections to the earths grid. I had a feeling it might also be something about the wire or copper itself.
If these specific lengths of copper wire tend to inhibit induction, or expand the diamagnetic field, then fast pulses may pass with less resistance. Simply due to a force in the wire controlling the nuclear tilt. Lyle had one config that randomly produced voltages, but he could never predict this effect.
44 feet 6 inches is the length he used to power all his scalar devices. 44 feet on the coils and 3 inches on each lead comming off them.
I wound several of these and they do produce a strong torsion field as well as react to crystals very strongly setting them into a vibration.
He combined them with 10 foot lengths wound at 90 degrees and said this was the config that would sometimes charge up to 30 volts.
I just placed one of these coils wrapped on a bolt between a funct gen and the scope. It is a perfect 4x wave of 5Mhz!
The square waves sync up perfectly with the sine wave ringing. The coils ringing rate is 4x of 5Mhz. Two sine pulses appears on each step of the square wave, what a surprise.
Definitly something unique about this wire length, but how does it relate to EM? And why does the 5Mhz appear in copper.
The ESR and NMR rates change with magnetic field strength. In copper with no magnetic field there is no ESR interaction.
If we can get photons to start moving one direction in a length of copper then voltage will appear.
Dave L
ronotte
Hi Dave,
generally speaking both Otto and myself did not find, associated with the 6" TPU, any exact coil lenght to justify a motive. Actually what I can say is that said coils (that we commonly name CC Contro Coils) must use short lenght of wire: generally best results are reached with 5 meter wire lenght. As soon as you move to higher lenght the effects are going to lessen ...but gradually. So You ask what do I mean for 'effect', well I only refere to output peak voltage obtained (on ECD mobius) and proportionally to light amount on  a mainly resistive load such as a 230V/60W lamp. So I've not find any applicable rule. The ECD for itself is a wide-band device tailored for pulse operation: it's auto-resonance is well beyond the 10 MHz range.  If you pulse ECD you will discover how easy it puts out power at almost any freq or freq combinations: the problem with ECD and with TPUs is that some set of 3 freq does it better.....very, very difficult to discover. Anyway the standard set F1, F2=2*F1 and F3=7*F1 seems the best up to now...but it must not be considered as definitive!
I've read many times the Latem coil issues, tried to better understand what he did in order to eventually duplicate his design but I gave it up for the lack of details. If you did it perhaps you may PM me such details.
Roberto
libra_spirit
5 Mhz rock solid signal identification.
Further study on these sine wave pulses that emerge on 90 degree coils setups, that seem to ring the E vector potiential, creating what resembles an NMR trace or a resonance pulse.
Ok we have dtermined they are not a result of NMR as a magnet does not effect them in frequency whatsoever.
I am however now dismayed that they also do not follow a length change of the wire and thus do not have to do the with wires resonant length! This is a direct conflict with current EM theory I believe.
If they are related to the wires length then how come if I cut the wires to half as long they are not effected? This brings up quite a puzzle. Besides the wires I am using are too short to generate a 5 Mhz resonance.
I have used different power supplies, one is an old 60 hz unit, and the other is a HF newer unit. I have not tried a 12 volt battery as of yet, but if this were a power supply recovery rate, then I would expect the frequency to vary between power supplies.
The only component I can identify them with is the c velocity of the photons traversing the coppers length. That is if I change the dielectric constant around the E field area there is a definite shift in the length of these ringing sine waves. They are only a fixed frequency in one dielectric substance.
This is all a surprise for me, as Mark had me nearly convinced that current engineering could explain this phenomina. I am not seeing this however as respect the rock solid 5 Mhz component.
Where does it come from, and why is it there in copper all the time?
There is a lightspeed connection we have realized over on the c_s_s_p group that may have bearing and yet I cannot yet explain this with a model connecting it all together.
Light has been connected to the number 144. I have no idea how this relates, however 44 1/2 is 1/4 wavelength of this frequency that copper seems to have built into it based on light velocity or dielectric constant. 44.5 x 2 = 89 x 1.618 = 144 = LIGHT
1.618 is phi
So this seemingly rock solid frequency appearing in the trailing pulse of a square wave in copper is related to lights velocity by a phi ratio factor?
Incredible.
The jury is still out on what this is we see on the scope traces and what it actually means to us.
Dave L
EMdevices
Dave..... Dave.....Dave     (with Oddesy 2000 accent  LOL)
See it's not NMR, but what is it?   It has to be electromagnetic resonance, you just need to figure out what is causing it.
One clue, not everything depends on length , it's only the standing wave resonance that depends on it (tesla coils, microwave resonators, etc..)  but most resonant things involving coils, expecially at low frequencies (where the wavelength is larger then your room  LOL)   are dictated by LC resonance, i.e. some capacitance and some inductance.
EM
