Powering a HFC using mixed H2 & O2
Started by Tacmatricx, December 28, 2007, 05:36:52 PM
Tacmatricx
Hi All,
I've been mulling this over as i'm still in the planning phase with my Stan M WFC replication. I am not really interested in powering vehicles at the moment but am looking at getting a WFC powering a homemade Alkali Hydrogen Fuel cell (http://www.youtube.com/watch?v=-cQg0Ur9Cko&NR=1) I was wondering... Couldn't you feed the mixed gasses into the H2 inlet port, loop the H2 outlet port over to the O2 inlet. Basically you have a single H2 and O2 in and a water vapour out?
I understand you guys will probably say i'll get reverse reactions canceling any potential out... but if you add a diode between the cell and the load, wouldn't the first part of the reaction (H2 <--> 2H+ + 2e-) fail to occur in the O2 side of the cell because the diode is blocking the electron flow?
If it works the cell would start up a little slow as the majority of H2 would be making it into the O2 side of the cell and being wasted, if it's fed only from a WFC there would be no CO2 to poison the Alkali HFC. When the cell is starting to crank and going to peak, i'm guessing  90% of the H2 will be absorbed in the H2 side leaving 80% O2 running to the O2 side of the cell. Almost like running on bottled gas.  ;D
Just need to work on a way to separate the potassium hydroxide from the output and feed it back into the cell.
Chris
Tacmatricx
More thoughts and Ideas:
A Diode has a forward voltage drop of 0.7V... thats the voltage of a cell... If you use a germanium diode, specifically a OA47 you will only have a 0.2V drop but it will only handle 1mA.
Looking at it carefully... I will be starting with a 9 cell stack and a single decent silicone diode giving me 5.6VDC after the 0.7V drop (a single diode between the stack and the load should keep each cell running in the correct direction). This will power my 5V Basic stamp controlling the WFC then pass through a simple DC-DC voltage doubler giving me the driving 12VDC.
I worked out that my stack should produce 4.1A per cell but because it is in series I will only have 4.1A @ 6VDC or 2A @ 12VDC.
This is enough to drive my Basic Stamp and the 0.5A WFC hopefully with a little more to spare. I'm hoping to prove the concept and convince me to put more money into the project.
Thanks,
Chris
sm0ky2
i see a problem with pressure for this type of "homemade" cell.
if you try to run it in reverse with 2 pressurized gasses:::
1) it will leak
and
2) your electrolyte will be spewed out through the outlett ports with the H2O
you can do a simple modification to the screws and make it pressure-resistant, but without a membrane the electrolyte won't las tlong under this type of operation.
Tacmatricx
Hi sm0ky2
I tend to agree... I prefer a factory PEM fuel cell myself (Or the new sealed AFC) but i'm not ready to commit to buying one at the moment. I have a modified design drawn up (Attached) that I intent to modify with a method of adding KOH solution as I know the water vapor produced by the cell will eventually dilute the Alkali. I will also look at a way of condensing the output and separating the KOH and water.
As for building the cell I am using Metal end plates at each end with Perspex insulators so that I can really tighten the bastard down and hopefully reduce leaks, The cell will be driven at 5-8 PSI and the water output will be set with a pressure release valve for 3PSI so that I'm not just blowing gasses through it.
If I still get leaks but it works, I'll happily sikaflex the gasket areas during reassembly and go from there. Anyone whose tried removing sikaflex knows there's no way it will ever leak if done properly and with perspex I can see each seal before I continue.
In the attached drawings the three perspex plates are from left to right the Rear, Middle (stacking) and Front plates. The front is where the H2 & O2 gasses enter and also where the water is extracted.
The only difference between a H2 and the O2 side it the gasket orientation, I have designed it with sealed pressurized gas lines that feed all cells in the stack. The rear tube going from H2 exhaust into O2 intake is the main concept of running the cell with mixed gasses and having the H2 be absorbed first leaving O2 for the second half of the cells. Otherwise it's exactly like the http://www.youtube.com/watch?v=-cQg0Ur9Cko&NR=1 except I will be using heatshrinked threaded rod for the stack.
Questions, Comments and Smacks for being a dumbass are all equally accepted :D I just want to get it right before I go buying the platinum ($$$)
Thanks,
Chris
Tacmatricx
Sorry,
I didn't really describe how the flow through the cell worked...
This design is based on holes in the Perspex plates, gaskets and filters lining up to create paths of flow ("fuel lines"). This is a stackable modification based on the on the following design http://www.youtube.com/watch?v=-cQg0Ur9Cko&NR=1
The only differences between an Anode and a Cathode in the stack are the orientation of the rubber gasket (Drawings attached, Determines the "fuel line" and "drain line" in the stack) and the orientation of the wire mesh so that the anodes and cathodes exit in different places and cannot touch.
The 12 1/4" holes around the cell are for bolting it together and the larger 1/2 inch holes line up between layers and allow the flow of gas between cells in the stack.
The Cell is intended to run below 80 Degrees C but the hotter it gets the less water will condense in the cell (I will probably be installing this in my solar heated hot water tank if it works well :D
Using this http://www.fctec.com/fctec_types_afc.asp as a guide this is how the cell works:
1) Viewing the cell from the front, H2 and O2 mixed gas from a Meyer fuel cell enters the inlet port on the front and pressurizes the Anode "fuel line" it then flows across the cell in the gap allowed by the gasket from right to left across the anodes of every cell in the stack from Anode "fuel line" to Anode "drain line" because of the gasket orientation. During this it looses H2 by 2 H2 + 4 OH- => 4 H2O + 4 e- which is permitted via a single high current diode between the cell and the load.
2) The Anode "drain line" flows out of the rear of the stack and valves permitting reenters the stack at the topmost Cathode "fuel line".
3) It then flows from top to bottom, from Cathode "fuel line" to Cathode "drain line" across the Cathodes loosing O2 in O2 + 2 H2O + 4 e- => 4 OH-, excess gas and water vapor then exit via the drain line.
If there is H2 gas present in the Cathode it will try to react in reverse and severely affect the cells efficiency, This I think will be blocked from occurring by the addition of a high current diode between the cell and any load. This prevents the electron loss in the reaction 2 H2 + 4 OH- => 4 H2O + 4 e-
Thanks,
Chris
