Muller Dynamo
starcruiser
looks like 16vpp on the scope shot, double that and you got the pulsed 15 to 16v dc output after the FWBR.
Regards,
Carl
nul-points
Quote from: toranarod on May 13, 2011, 03:56:14 PM
The neo magnet on the back of the ferrite core is very important we can see why he used them now. Once again it was too complicated to be a hoax.
The polarity of the magnet can increase motor speed and out put amplitude or decrease output amplitude. Dependent on magnet pole
As with all pulse motor design timing is every thing. The only thing that concerns me is the output voltage amplitude the CRO is set on 2 volt divisions. This will double when both coils are in series but I don’t know at this stage how it got to 12 volts. I still think he had the DC to DC converter for a good reason.
thanks toranarod, that's great feedback
greater revs will give you more volts out, as will closer gap between core and rotor mag
you may find that a full complement of Gen coils helps too
Romero said that bigger coils/cores + extra ferrite mags on the stator mags helped - and if you haven't tried this yet, neptune pointed out that Romero got improvements by using non-magnetic 'shims' as spacers for the stator mags
many thanks
np
[Edit: oops, forgot to say - he *had* to use the DC converter after already looping without it - the voltage started to rise without control and started to over heat his coils - so Gyula suggested the converter to 'clamp' the motor drive & therefore keep the o/p stable.   it's not necessary for any other effect]
http://docsfreelunch.blogspot.com
khabe
Of course no needs for one polarity magnet poles. When coil ends are A/a, then you need to connect coils parallel just as A/a=a/A=A/a=a/A ... and to use alternate poles. Then pulse driver must to be full bridge push-pull of course ...  Also all these additional opposite magnets and  flux canceling were just a raving.
And about RC 3-phase PM motors - these are not something like distinguished, especially when windings will be removed. Where you can make this "open magnetic circuit" when there is rotor back iron and stator also has flux returning ring  ::) all is closed as much as possible, at that there is maximum 0.5mm airgap.
So, when he told he will make selfrunners from these motors, then it means that all "sciential talking"  was just a blether.
He just found out how this US "home loan" guy made his trick, is it SuperCap or UltraCap or hidden battery, it does not matter,
because  ... tragicomedy is that several hundred believers around the world running by Shops trying to buy and order every kind of stuff , included expensive today neo magnets and ... oh dear ... sewing machine bobbins  :o
You did like to see big rc motor? This is German made Plettenberg, yeah costs under 1k $,
http://www.google.ee/search?q=plettenberg+Predator&hl=et&biw=1886&bih=894&noj=1&prmd=ivns&tbm=isch&tbo=u&source=univ&sa=X&ei=t4vNTb3VMYWAOvfGqYoN&ved=0CHYQsAQ
Chineses:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14426
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14427
cheers,
khabe
neptune
@ khabe Can I ask you three simple questions .
1. Do you believe that Overunity is possible .
2 Do you believe that overunity has been achieved.
3 Do you believe that it can or will be achieved in the home workshop .
If you please answer these questions , I will be able to understand your point of view better .
DadHav
Quote from: nul-points on May 13, 2011, 09:07:08 AM
apologies for my slow-wittedness, John
what did they miss?
did you mean that Classen missed something that Romero stumbled on?
Classen's device appears to claim a CoP similar to Romero's
maybe it's me that missed something? (wouldn't be the first time - or the last!)
any clarification welcome!
thanks
It's just me, I haven't read enough to see that some of these other awsome builds are over unity. Maybe I'll eventually catch up on things.
John H
