Muller Dynamo
nul-points
...just a quick thought, all
i suspect that the underlying 'principle' behind what we're seeing in this and other rotary devices, is the 'mechanical advantage' we can achieve by 'sliding' magnets (or energised coils) sideways into an aligned axis position, where we can then benefit from the rapid flux change event provided by the close & rapid location of a magnet and a core/coil
the inherent force of the magnet is able to provide work through the flux change event - all we have to do is to make sure that we minimise the work 'we' do in getting the magnet into & out of position
look at Rod's device - much of Romero's device is stripped away - Rod is only moving magnets past coil/core units
i believe both Rod & Romero are honestly presenting what they've found
Romero has shown us how to take it to a new level
if my thoughts here are correct, then we can find plenty other ways to do this
gotta run - give my love to khabe!  ;)
np
http://docsfreelunch.blogspot.com
Pirate88179
I was thinking that possibly using a true earth ground, like Kapanadze, might allow other energy to enter the system and make self-running easier to obtain?  This is just an observation on my part, I know that Romero did not do this.  I was just thinking that this might help in jumping over the COP=1 barrier a little easier.
khabe
Wheres different between Bedini and Ron´s machines? One is radial, another is axial, question about architecture, gives not any supernormal excellence.
You like you can built Bedini radial as outer rotor.
http://www.youtube.com/watch?v=nA2KtZ45nXA&feature=related
Muller built axial, just easy to have two row coils, more output coils with volumetric economy. Rectifiers after each coil or coils are grouped and then rectifiers ... matter of taste. Once rotor rotates cogging does not interfere anymore, especially when to look at Rom´s large air gaps. At that 9 coils vs 8 magnets is far not the only low cogging choice.
Someone offers to have outer ferrite tube additionally to inner ferrite rod?
Yeah ... when the same direction magnetic flux from outer and from inner side then what you´ll get from coil is zero  ::)
Elementary school physics  :o
cheers,
khabe
neptune
@ khabe . in your last reply , It is not clear if you believe that Bedini technology is OU .Or not OU .
khabe
Quote from: neptune on May 14, 2011, 06:11:25 AM
Of course not OU,
Bedini is honest man,
he does not claim this is OU,
http://bedinimotors.blogspot.com/
cheers,
khabe
