Muller Dynamo
0 Members and 202 Guests are viewing this topic.
Aphasiac
http://www.stickam.com/viewMedia.do?mId=191436737
This is the video Romero had called "10W OU", or something like that. It was one of the earliest videos on the Muller Device.
And I think it's also already posted here: http://freeenergylt.narod2.ru/muller_dynamo/
Looks like already a duplicate of the ones you have. If so, my apologies.
Aphasiac
--EDITED.
The real voyage of discovery consists not in seeking new landscapes, but in having new eyes. --Proust
gauschor
@plengo: thanks a lot, this demonstration video is very interesting.
Might this be the major key for the Romero device? That it simply needs less power for rotation because of less cogging?
nul-points
Quote from: plengo on May 14, 2011, 11:52:11 AM
There has been concerns from many members that such small coil would not be able to produce more than 2 or 3 volts when used as a generator.
In this video, I am demonstrating a very simple experiment that it is very possible and indeed very simple.
http://www.youtube.com/watch?v=3pHLKPciCGM
Fausto.
excellent demo, Fausto - nice work
looked to me like those are the same coils (from Radio Shack relays) used in the small self-runner by Rod, which i reviewed here earlier
thanks
np
http://docsfreelunch.blogspot.com
erikbuch
@CLaNZeR
You might want to rethink the small magnets right outside the big magnets, it might become a very weak spot. As it spins, the big neos get very heavy... dont think you would want them come flying around. Besides, the small ones might disturb the magnetic field of the big ones.
As long as the small ones are 45 degrees apart it dont matter where you put them. You just move the hallsensors accordingly.
Just my 2 cents.
Best regards
Erik
plengo
Quote from: gauschor on May 14, 2011, 12:24:43 PM
I think this is only demonstrating one of the thing his motor has. This will definitely help with the cogging and easy the rotation. It will not eliminate cogging specially when using the energy generated by the generating coil BUT there is a very fine line where the generation of energy and the cogging is balanced to its best.
So this technique will help fine tunning, as Romero said, the position of each individual magnet/coil arrangement while pursuing the most energy.
Now the biggest problem to overcome is still Lenz's law where once using that energy there will always be less energy generated than user inputed.
I think for this next problem the solution lies in the magnetic tri-gate of Howard Johnson.
You see, when the coil is creating energy because of the passing by magnet on the rotor and this coils has a load it will create an proportional and counter EMF, therefore another polarity magnetic field, that opposes the coming rotor magnet. This is in fact, at least to me, a 3 poles arrangement seen in the tri-gate concept.
Look at the picture and try to see where is in Romero's one "cell" (generator coil / biasing magnet / moving rotor magnet) is each one in the tri-gate concept!!!
Fausto.
