Muller Dynamo
0 Members and 155 Guests are viewing this topic.
neptune
@khabe .Just a quick question . You know the type of magnets used in microwave oven. I call them ceramic magnets . Are they in fact rare earth magnets ? What I want to know is this . If China stops all exports of rare earth magnets and materials , what will be the strongest magnets we can then get ?
plengo
Quote from: gauschor on May 14, 2011, 02:26:28 PM
I don't think it's a good idea to overcomplicate and confuse the design with "magnetic gates" at this stage - afaik the "gates" from Howard Johnson never worked (and neither did his linear accelerator track, it could be seen in his own video). Let's keep to what we have, which is: the magnets on the backside of the coils.
I am not trying to over complicate anything. It is what I can see in this motor. The cogging effect reduced by the biasing magnet. Once load is used the counter EMF will create a counter manetic field similar to the tri-gate and that will help the rotor magnet to pass by even easier.
I know that those tri-gate motor never worked, at least that I have seen, but indeed they do pass by on the first gate pretty well although on longer ranges they fail. The dynamics of the interaction of the rotor magnets, coils and biasing magnets are not easy to understand neither envision.
I am only trying to explain what I see as part of those dynamics.
Fausto.
porteran
Quote from: plengo on May 14, 2011, 01:07:01 PM
[snip]
Now the biggest problem to overcome is still Lenz's law where once using that energy there will always be less energy generated than user inputed.
[snip]
Fausto.
...There is research that overcome Lenz's Law...
http://www.youtube.com/watch?v=u3gVfltiO-E
plengo
Quote from: khabe on May 14, 2011, 02:10:21 PM
What you hoped there must to be or come, Fausto  ???
Are 13.5 x 100 mm, N50,
its boring to find steel balls, somewhere I have but cant find, because took M12 nuts.
Set up is correct, you can see small red marks.
NS corner  and to the SN corner - both pulls this separate magnet, no matter from what side to start.
And it does not matter what directon to use - corner nut pulls N as well as pulls S ,
polarity does not matter ... direction does not matter.
Dont want to try without rails,  will brake surely ... I have rails but why ...  what I will see ... or you do not know yourself  ::)
forgive me but I could not really understand your point. Thanks for the try. Can you, please, re write your point so that I could follow?
Thanks,
Fausto.
plengo
Quote from: porteran on May 14, 2011, 04:00:07 PM
YES, I was exactly thinking about Thane too. I just don't know yet how Romero's motor does the same (if it indeed does).
Fausto.
