Muller Dynamo
0 Members and 56 Guests are viewing this topic.
CLaNZeR
Was calculating the windings and if using a accurate winding machine with tight tolerences, I came up with the following:
10mm / 0.875mm = aprox 11.42 turns
So 300/11.42 = 26.62 layers
26.62 layers * 0.875 = 23.29 mm
Now add the 6mm ferrite.
Yet Romero coils look about 20mm and they were hand wound?
Did romero ever post the resistance of those coils? be interesting to compare when I have wound one, before doing all 18 of them.
Cheers
Sean.
http://www.overunity.org.uk
Cherryman
@ Clanzer
Hi, Not sure if you noticed, but Rom used a 25cm disc. I noticed your drawing has 20cm.
Quote from: romerouk on May 06, 2011, 12:50:20 PM
Sorry, diameter is 25cm and distance from the rotor to the coils is about 3.5-4mm.
erikbuch
I think it was 4.86 ohm pr coil.
Best regards
Erik
Staffman
@ Clanzer
I think he said it was close to 2 Ohms (between 1.5 and 2), although I can't find the post. If I remember correctly, he said that each coil was different because they were hand wound with twisted litz. His wire (7 x 0.125) would be closer to 0.375 diameter if you bunch the 7 wires together....
Edit... i'm probably wrong about the ohms. Still can't find the post.
CLaNZeR
Quote from: Cherryman on May 14, 2011, 05:24:30 PM
@ Clanzer
Hi Cherryman
Yep and later then he corrected himself saying:
Hi,
I have measured the rotor and it is 20cm, sorry. I had so many changes and I also had a 25cm and a
35 cm rotor in another setup.
I spent about 4 hours today reading every post in this thread, before I started to draw up, so hope it is right :)
Cheers
Sean.
