Muller Dynamo
0 Members and 93 Guests are viewing this topic.
tysb3
Quote from: Dave45 on May 14, 2011, 07:34:09 PM
Hey guys im looking for a good rotor bearing anyone have any ideas or maybe link to order, been holding back but its time, got to play with this myself.
David
gotoluc
David
The best available
http://cgi.ebay.com/Full-Ceramic-Skate-Balls-Bearing-608-8mm-22mm-7-Ball-/150218727165?pt=LH_DefaultDomain_0&hash=item22f9bbdefd
e2matrix
I think that is the best bearing for skating.  And maybe a vertical rotor but will it handle high RPM?   I read that skate bearings may not be best though for a horizontal rotor like this build Romero did.  A thrust bearing was mentioned as a good choice.  I also think any VCR head bearings as tysb3 mentioned would be a very good choice.  You can probably pick up a used VCR for a lot less than the cost of one of those skate bearings and then you can scavenge a pile of other good electronic parts too ;)
wings
Quote from: tysb3 on May 14, 2011, 10:06:29 PM
@ tysb3
good choice but you have to manage the non horizontal fixing point!
Magluvin
Quote from: e2matrix on May 15, 2011, 01:59:43 AM
Well with the type of pressures a skateboard endures, I would sat that these bearings could be champions here.
Boca Bearing has ceramics. Last I looked was back in the time of the Whipmag. They have a lube called dry lube for them.
I had not gotten any for the project, but was interested at the time.
I used bearings from a hobby shop. I thoroughly cleaned out the grease and worked in graphite powder.  I had gotten rundown times of over 14 min from 1000rpms.  I have vids on YT, 2 in a row as there was the 10 min time limit.  It ended up much better than dry or any oils I had tried.
http://www.youtube.com/watch?v=FiGjK3P7JBY
http://www.youtube.com/watch?v=eVXtRSxm73g
Mags
